comp r lifters
Old Mar 23, 2006 | 10:50 PM
198c5's Avatar
Default comp r lifters
are comp r lifters ok? i have a set waiting on new short block. and can i still use the stock rockers?
Old Mar 23, 2006 | 11:35 PM
cowboysfan's Avatar
to answer both questions yes. I'm running Comp Cam 850 lifters & stock rockers on a Comp Cam 231/237 .589/.595 112+4 lsa. about 2k miles w/ no problems.
fuerzaws6
Old Mar 24, 2006 | 05:00 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
There is nothing wrong with the "R" lifters. The horror stories you hear is only about them not being setup correctly. And as is with everything that involves moving parts and geometry...It will naturally screw itself up. I run the com cams "r" lifters and stock rockers still as well in my Z28...no problems.
Old Mar 24, 2006 | 07:04 PM
198c5's Avatar
how do u set them up wrong if u torque the stock rockers to spec?
Old Mar 24, 2006 | 10:59 PM
Unaffliated Racing's Avatar
Because the "R" series, part number 875 is only supposed to have .002"-.004" of preload. If you just torque them to spec you will have like .050" preload...which is wayyyy too much.
Old Mar 25, 2006 | 06:20 AM
SAM98WS6's Avatar
because R lifters are to be used with adjustable rockers only...and thats .008-.010" preload COLD.
8000 miles here and no issues whatsoever.
Old Mar 25, 2006 | 10:02 PM
198c5's Avatar
thanks for the info. so i guess i will need adjustable rockers? may just use stock lifters to save $ so i will have a set for sale.
Old Mar 26, 2006 | 01:39 PM
GOGO's Avatar
Do morels need adjustable rockers or can I use them with my stock rockers?!?!
Old Mar 26, 2006 | 03:31 PM
Viper's Avatar
No, you can use stock with Morels. Get the preload to .030 on them.
Old Mar 26, 2006 | 04:26 PM
GOGO's Avatar
sweet! Thanks.
Old Mar 26, 2006 | 08:36 PM
198c5's Avatar
if i use the comp r lifters guess i will need to change my stock length push rods to get the correct preload?
Old Mar 28, 2007 | 02:03 PM
jegten's Avatar
Unaffiliated and SAM98WS6-
so, how do i then set these lifters up?
i have a pushrod length checker i will be using to find out the correct PR length, but, though i understand both posts, am confused as of what to do now, .008-.010 preload COLD? .002-.004 when?
thanks for the specific preload info on the R lifters. i didn't know it was .002-.004.
i really appreciate it. finally getting to do the H/C install, and would like to use the R lifters i have, and wouldn't want to have "all" the problems we hear about them.
PS: oh! i will use stock rocker arms.
Old Mar 28, 2007 | 02:07 PM
brad8266's Avatar
To get to the proper small preload on those lifters all you have to do is use a pushrod checker to measure length to zero lash then add proper preload, and like magic you now have your new PR length that will keep the lifters at the proper preload.
Old Mar 28, 2007 | 02:08 PM
brad8266's Avatar
Exactly.
Old Mar 28, 2007 | 03:19 PM
1997bird's Avatar
.002"-.004" with the engine oil warm/hot.
Old Mar 28, 2007 | 04:15 PM
jegten's Avatar
thanks, brad8266,
i get this, but, the small preload, what is it? 1997bird just mentioned .002-.004 warm/hot. and someone up there said .008-.010 COLD. lol
since the engine will be cold, because i will be assembling it, then, is it .008-.010? thanks guys.
Old Mar 28, 2007 | 04:17 PM
brad8266's Avatar
thanks, brad8266,
since the engine will be cold, because i will be assembling it.
The cold preload on the Comp lifters is supposed to be .008-.010, that is a small amount of preload compared to the recommended preload on the stock lifters.
Old Mar 28, 2007 | 04:19 PM
jegten's Avatar
LOL
you're quick!!
thanks! i was editing my post when you responded. he,he
got it!!
it's just a lot of people have complained about these lifters, and, i have them, and want to use them.
PS:if you look up in the posts, people are saying get the preload to .003. or get it to .002-.004, because .005 is way too much. hence, my confusion.
Old Mar 28, 2007 | 04:23 PM
brad8266's Avatar
LOL
you're quick!!
got it!!
LOL, I stay on this bitch all day at work, we havent been busy lately.
I would guess people complain about them because they are preloading them to stock lifter preload values which is in the .050 and up area, these lifters need low preload which is done by having shorter pushrods.
Old Mar 28, 2007 | 04:25 PM
jegten's Avatar
got it!!!
LOL
just disregard my last edit. it is .050 and not .005 as i wrote. i get it!!
man!
yeah, they are expensive, but they are supposed to be good.
