Stupid oil pump.......
Old Mar 25, 2006 | 05:02 PM
99whitews6's Avatar
Default Stupid oil pump.......
I got the 408 running and started doing some part throttle tuning. When it idles at a light the oil pressure is around 30-35(per the stock gauge). When take off slowly its around 45-50 and when I give her some gas she is around 60.
Should I be worried about the low oil pressure at idle?
Old Mar 25, 2006 | 05:06 PM
indyboom's Avatar
low.. Man thats still good man!! All thats needed is 7psi per 1000 rpms...
Old Mar 25, 2006 | 05:19 PM
99whitews6's Avatar
Sweet!
Old Mar 25, 2006 | 05:37 PM
indyboom's Avatar
yeah no worries!!!!
Old Mar 25, 2006 | 06:38 PM
black_z's Avatar
Should be just fine youssif. Is it a stock LS6 pump? What oil are you running?
Old Mar 25, 2006 | 08:07 PM
99whitews6's Avatar
TSP ported ls6 pump. Running regular 5-30 until the engine is broken in then I will be changing to synthetic.
Old Mar 25, 2006 | 08:26 PM
JL ws-6's Avatar
Race your car!
you might be running oil that is a little thin. What did the engine builder reccommend for oil weight for the clearances that they used?
Old Mar 25, 2006 | 08:41 PM
99whitews6's Avatar
ummmmmmmmmm........they didnt! LOL
Old Mar 25, 2006 | 08:51 PM
mr2guru's Avatar
don't sweat it.... I had the exact same pressures. I bet they used .022-.023 on the rods and mains. The stock clearances are considered too "tight" by most engine builders
Use some 10w-30 castrol GTX for about 1000mi then switch to a 5w-40 or 10w-40 synth. and you'll see that oil pressure jump 7-10psi.
You're looking for trends with an oil pressure gauge anyway
Old Mar 26, 2006 | 08:54 AM
99whitews6's Avatar
Hey there, FFHP built my shortblock so what did they tell you as far as oil goes? I am assuming when you said you had the exact same pressures you meant that for your current 408 listed in your sig.
Old Mar 26, 2006 | 09:16 AM
StreetStalkerZ's Avatar
I would go with some standard Castrol 10-30W,that's what LME told me to run when i fire up my new shorblock. I always run standard oil 10-30W for the first 3-5K miles but that is what i like to do to insure a good break in. Your preassure is fine but if you want more the thicker oil will give it to you.
We installed a TSP ported LS6 pump on a local guys car a few months back and was getting 45-50 psi at idle with 10-30W on a 80K mile stock bottom end.
Old Mar 26, 2006 | 06:17 PM
mr2guru's Avatar
10w-30 winter and 10w-40 summer.
I run amsoil 5w-40 synth after break-in.
