Spiral locks ...
Old Mar 27, 2006 | 10:03 PM
Flyer's Avatar
Default Spiral locks ...
There has to be an easy way!
Old Mar 28, 2006 | 09:15 AM
Flyer's Avatar
Am I the only one that's had to deal with these things?
Old Mar 28, 2006 | 09:43 AM
Randy WS6's Avatar
no your not ,but there is no easy way, but spread them apart and start it in to the grove and take a pocket screw driver and roll them in place.
Old Mar 28, 2006 | 09:46 AM
Greg Fell's Avatar
The key is to spread them apart wide. If you get them wide enough, you can do with no tools at all. You have to get the 'top ring' off the top of the piston, so it is not touching it. It should spiral in after. Good luck, its pretty easy once you get the hang of it.
Old Mar 28, 2006 | 09:47 AM
Randy WS6's Avatar
my pistons had double locks four per piston, and there harder to take out than putting in ,to me.
Old Mar 28, 2006 | 10:12 AM
SAM98WS6's Avatar
there is a tool but i cant find it for some reason
here is a similar tool...
http://www.midwayautosupply.com/deta...ption.asp?2033
makes the job real easy
Old Mar 28, 2006 | 12:25 PM
Flyer's Avatar
I figured there was a tool to it if no trick. I got 4 done last night resulting in 2 raw fingertips.
Thanks for the help guys.
