Should I replace rod bolts
Old Mar 29, 2006 | 05:02 PM
magius231's Avatar
you can do it without pulling the K-member...
https://ls1tech.com/forums/generation-iii-internal-engine/474402-rod-bolt-swap-write-up.html
Old Mar 29, 2006 | 05:08 PM
Ωmega's Avatar
That seems like more work than dropping the K member.
Old Mar 29, 2006 | 05:57 PM
198c5's Avatar
my brothers 98 c5 rod let go at 6800 rpm have not tore it down to see if it was rod bolt. just ordered a new short block from tsp. i have pulled the heads and piston comes out of block a little. barely hit head thank god the head was not hurt! 59 cc afr 205's heads are not cheap!
