Cam too big
Old Mar 28, 2006 | 05:17 PM
93ChevExt5.7's Avatar
Default Cam too big
Okay - so what are the symptoms of a cam being too big for either the torque converter or the car in general (vaccuum, etc)?
Old Mar 28, 2006 | 06:56 PM
s346k's Avatar
spinning the engine to 7k and not peaking? heh
i say no cam is too big as long as your engine is capable of using the entire powerband...of course this mean doing so without putting a window in your block because you're shifting at 7,400..
Old Mar 29, 2006 | 04:57 AM
cantdrv65's Avatar
Post
A cam is too big when you sacrafice more area under the curve for a higher peak dyno number. Many, over cam the car then wonder why they are getting walked by a much smaller cam.....If you go with a big cam and spin high you have to have the compression to get a good DCR or the small cam which has a higher DCR with less static compression is going to make more average power. Too big a cam requires more compression, higher peaks and is generally not very traffic friendly etc. Its different for each person and combo...
