Thermostat, Which one to use?
Originally Posted by PREDATOR-Z
It doesn't mean that the car will run 160.
Originally Posted by GuitsBoy
It sure does in the northeast during winter! A lot of guys wonder where all their heat went to. Even in warmer climates, the fans dont operate above 30 MPH unless youre over temp, so the operating temperature is indeed dictated (atleast on the highway) by the thermostat.
So what is the consensus? Stock stat with reprogrammed fans, or 160* stat with reprogrammed fans?
I live in Missouri, where we have the most unpredictable weather. It will be over 100 in the summer and 0 in the winter. And in the fall and spring, you have no clue what you are going to get. A couple days ago, it was like 20 degrees, and now it is 65 outside.
I just want to get what is best for my car. Can someone help me out? If I stick with the stock stat, what would you reprogram the fans at?
I've got HPTuners on the way, so I can change the fans to do whatever I want. I'll stick with the stock stat for now, but should I reprogram the fans? And if so, what on/off temps for each?
