Low oil preasure...help
Old Mar 31, 2006 | 09:53 PM
DONAIMIAN's Avatar
Default Low oil preasure...help
My gauge is reading a steady 10psi. The needle isnt fluttering, or bouncing, and the motor isnt ticking or knocking so im pretty sure no bearings were spun. What could be the cause of this? Im totaly lost and this is my DD, I dont need this.
Old Mar 31, 2006 | 10:38 PM
SUX2BU's Avatar
How bout some more detail?
did this just happen out opf no where?
did you recently install or change something?
you low on oil?
Old Mar 31, 2006 | 10:52 PM
DONAIMIAN's Avatar
I romped on it a little and happened to look down and noticed the gauge was pointing where it shouldnt be, I didnt expect it at all. Nothing has been changed in the motor except the oil for the last 2.5 years. According to the dipstick the oil level is fine.
Old Mar 31, 2006 | 11:04 PM
SUX2BU's Avatar
Does it go up like normal when you accelerate?
Old Mar 31, 2006 | 11:09 PM
DONAIMIAN's Avatar
It goes up with RPM, but not like normal. I dont want to run it too high up in the RPM and chunk rods or risk spinning a bearing. Is it possible for the filter to be defective and restrict the flow of oil? thats the onlything I can think of off the top of my head.
Old Mar 31, 2006 | 11:11 PM
ashade98's Avatar
Start by changing the oil and filter.... then go from there.
Old Mar 31, 2006 | 11:16 PM
DONAIMIAN's Avatar
Have that lined up for tomarrow morning, if that dosent fix it then I guess ill open the motor and take apart the oil pump to see if anything is stuck in there.
Old Mar 31, 2006 | 11:23 PM
SUX2BU's Avatar
Yeah do that and if that doesn't work throw a new oil pump on it as a last resort. You'll need a new one anyways if it is the motor.
Old Apr 2, 2006 | 11:16 PM
DONAIMIAN's Avatar
Changed the oil and filter, everything looked good, but now im thinking maybe its the sender. There was no metal in the oil, and considering I ran it through 2nd and 3rd twice before I saw the gauge and didnt throw a rod leads me to belive it may be the sender. Any thoughts?
Old Apr 2, 2006 | 11:32 PM
SUX2BU's Avatar
swap out with a buddy.
Old Apr 2, 2006 | 11:46 PM
heavymetals's Avatar
I think you should check the sender.
I had mine fail on me after racing a vette and it scared the **** out of me.
Was a bitch to get at, but was the problem.
Old Apr 3, 2006 | 11:22 PM
DONAIMIAN's Avatar
When it failed, did it read low, or not read at all?
I went to my friends house where the cas has sat for the last four days and drove it home tonight, its about a mile and a half away. It drove fine, not making any noises out of the ordinary. I watched it the whole way to make sure the gauge didnt drop to 0.
