think I F up computer
Old Apr 2, 2006 | 07:14 AM
silver 2000 ss's Avatar
Default think I F up computer
Two months ago some jackass hit the rear quarter panel on my ss, so instead of haveing a boby shop do the job I did. SO I took the quarter panel of and welded on a new one no big deal, Had the battery disconected for about 1 month, last night I finish it all up started the car and it will not stay running. I have to hold my foot on the pedal to keep it running,do you think my computer is messed up, or can it be reset if the battery was diconected for to long,the car was ls1 edit awile back and it got a cam,ls6 intake,headers exhaust and some other stuff. also I am noy getting any ses lights. what do you think.
Old Apr 2, 2006 | 07:25 AM
anybody know
Old Apr 2, 2006 | 07:27 AM
PREDATOR-Z's Avatar
Clean your TB idle sensor.
Old Apr 2, 2006 | 07:31 AM
can it get dirty form just sitting in the driveway
Old Apr 2, 2006 | 07:38 AM
Bill's 02 Z-28 SS's Avatar
the car needs to relearn it's settings. drive for a couple of minutes, it should get better - most time is about 15 minutes. this happened to me after I disconnected the battery for awhile.
Bill
Old Apr 2, 2006 | 07:40 AM
I did not know the computer can do that also do you think it can be a weak battery
Old Apr 2, 2006 | 12:58 PM
yes - if the voltage falls below a certain value, the computer thinks it don't have any voltage. all the setting are cleared, when you power up it does not know what the values were.
Bill
Old Apr 2, 2006 | 02:04 PM
ringram's Avatar
Its just idle and fuel trims that get reset.
Everything else will be ok as its flash memory. If it started its probably ok.
See if it sorts itself out, otherwise you may have bad gas in the tank (maybe got water in) or stuck IAC motor etc. Get some nice clean gas in the tank and see how it goes.
Check your plugs, wires etc.
Old Apr 2, 2006 | 02:21 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by silver 2000 ss
boby shop
Haha
