How much of a difference in flow between ports?
Old Apr 3, 2006 | 06:44 AM
ATVracr's Avatar
Default How much of a difference in flow between ports?
My CNC ported head flows from 5-13 cfm different between ports on the same head.
Main difference being 13 cfm at 500 lift.
Is that something I should be concerned about? Seems like a good bit for a CNC port.
Anyone else had more than 1 port on there heads flowed to see the difference?
Old Apr 3, 2006 | 10:55 AM
Xtnct00WS6's Avatar
That doesn't sound right. Who did the CNC work? Is there visually a big difference between the ports?
Old Apr 3, 2006 | 01:47 PM
GrannySShifting's Avatar
The ports look the same but you wouldnt be able to tell much from the naked eye.
Its a well known aftermarket casting.
