Spark Plugs For Darts Confused
The "R" before the 5671A-x designates resistor.
PS - Good looking run, KP.
At least that what the rep who used to give me free plugs told me years ago lol. I'm pretty sure the R5xxx plugs are all non-resistor.
I didn't get one either, sent you a PM with e-mail address.
I just checked and the R5671/2 and the autolite 3924 (AR3934 actually) are non resister plugs. Some of the 'R' series plugs are resistor, when they start with BPR or FR or TR the 'r' means resistor, when they start with just an R that means race. NGK is no doubt the most confusing numbering system there is.
I would say FR5 for stock apps and 3922 or 3923 for N20/FI etc just to be on the safe side and keep it resistor. Maybe check with NGK on which other plug would be exactly the same as a FR5 in the 6-7 heat range if people want the V-powah
Have any of you ever done an ion current test on your engine????? If not, you should probably do what they recommend.
I have used plenty of NGK Iridium plugs and Denso Iridium and they are both great. Never had a problem. I have done enough testing to know which heat ranges to run. The thing always to remember is if you get a plug thats too cold, it is a heck of a lot cheaper to replace than a piston or 3!!!!
And always run the iridiums. You may not want to spend the money now, but you will be able to run 1 heat range colder and the plug will stay clean. It is just money well spent.
And for god sake stay away from those +4 Bosch things!!! Those things shroud the spark so bad I am suprised that they even work.
If you want the best plug in the industry, it is the Denso Iridium.
Oh, here's a quick breakdown:
Stock LS1 - Denso 16 - NGK 5
LS7 - Denso 20 - NGK 6
Denso 22 - NGK 7
Denso 24 - NGK 8
Denso 27 - NGK 9
Denso 31 - NGK 10
I would give out power numbers for each plug, but every situation is a little different. Just remember that you need a colder plug for a 5.7L making 500hp than you do for a 427 making the same power. Its all about the BMEP.
Bottle rocket, that all depends on how much power you are going to be making.
For any cross references, you can go to www.ngk.com
