Roller rockers?
Old Apr 5, 2006 | 12:37 PM
triblk6spd's Avatar
Default Roller rockers?
i have read almost every thread on this subject and still have a question. i'm looking to do a set of roller rockers on the C-5. is there anything that will be an upgrade from stock, a direct bolt on, and easy to install? i wish there was a difinitive thread on this subject but i have searched with no luck. any help would be cool. thanks guys.
Old Apr 5, 2006 | 12:46 PM
PREDATOR-Z's Avatar
Some of the best are CRANE GOLD and Jesels
Easy to install are the nonadjustables (why bother changing from stock)
The adjustables all require some sort of clearancing, and adjusting of course, so not directly EASY to do.
Old Apr 5, 2006 | 01:44 PM
triblk6spd's Avatar
i was thinking hard about the Crane Gold 1.7's. part #144750a-16 Also do i need the whole kit or just the rockers?
Old Apr 5, 2006 | 02:29 PM
PREDATOR-Z's Avatar
Whole kit as they require guides and shorter p-rods IIRC
Old Apr 5, 2006 | 03:17 PM
triblk6spd's Avatar
they are calling this stuff a "bolt on". why are the install instructions crazy complicated?
Old Apr 5, 2006 | 03:30 PM
WhiteRhino's Avatar
They are actually very easy to install. The directions aren't as complicated as they seem. Spin the motor over by hand to find 0 lash, spin motor again, find 0 lash. I did this like 4 times to make sure I had 0 lash. Just make sure you aren't depressing the lifter cup when setting 0 lash. Then after you find 0 lash you dont spin the motor at all. tighten the rockers a 1/4 turn at a time waiting about 10 min between each turn till you go 1 & 1 /2 to 2 full turns.
This is from the Vinci site. http://www.vincihighperformance.com/...TRUCTIONS.HTML
Old Apr 5, 2006 | 04:02 PM
Nasty N8's Avatar
Stock replacments Harland Sharp full rollers bolt on and go just like stocker. Or we can modify your stock rockers with new bearings and trenions talk about easy and a perfect fit.
Nate
Old Apr 5, 2006 | 11:05 PM
triblk6spd's Avatar
i'll call on thurs. thanks.
