ET head owners inside please....
thanks.
The owner of the shop told me after his testing the only head he has used since have been ET heads.
No tricks or 4.125 bore testing either!
FWIW ... only AFR and ETP have been accurate in their numbers, at least from my testing...
Ed
EDC can you post your 215 numbers too?
This is the set I bought (225s) and Force Fed High Performance flowed them on their bench.
Intake
Head…………Int. Valvelift…………………..........Runner
…..….200….300….400….500….550….600…….Volume…………Comm ents……….
"Z"....137...211...270....310....324....336.....24 0 cc's ..New "Best" peak #'s
Exhaust (with pipe)
Head………….Exhaust Valvelift…………………..Runner
……...200….300….400….500….600............Volume
"Z"....117....170...215...241...253........... .95 cc's.....BIG port / strong #'s
https://ls1tech.com/forums/generation-iii-internal-engine/317323-interesting-flow-data-long-thread.html
https://ls1tech.com/forums/generation-iii-internal-engine/470839-just-got-news-etp-225-flow-numbers-added-full-flow-numbers.html
The ETP 240's set a new peak record on Tony Mamo's flow bench!
These ETP heads look like they will give AFR a run for their money.
Another thign I am hearing is that the fast intake, even after porting, is a restriction to the heads as well. If that is the case, then what is the option? I would say the edlebrock single plane, but I don't want to cut the cowl. I would make every attempt and try to have as much cut off the top of the intake on a plane, but it still leaves the question of what to do with an elblow, as that is supposedly a restriction for a n/a car. The 4150 style TB is nice, but I need to be able to run an air cleaner, and I'm not going to cut the entire cowl out to fit one on it, that's just not happening.
Carrie from ET suggested to me to go with the ls7 style head they are amking, the one for a 4 inch bore. I am not sure about the total cost, but I know that an ls7 intake, and a TB that will for for a cable driven car ( my transam) will be needed, ls7 rockers will also be needed, map sensor I think will need changing, fuel rails, and I understand the injector is different somehow. Now some of that doesn't matter, as I was planning on a fast 90/90 setup, as well as a set of 42 lb/hr injectors, but the added cost of a rocker set, and any other stuff, plus the price of the ls7 head is putting me over what I want to spend by a good amount of $ Originally, a set of AFR 225's was the route I was going to take, I cen justify the added cost of the heads, just not sure if I want to spend another 1500 in added parts.. this motor deal along with the trannys swap is adding up to enough as it is.
I wish I would have been able to have my old motor stay together for another year so I could have gotten the car itself finished first, but fate decided that to not be the way.. would have given all thsi new technology another year to settle out, prices to settle, availability, etc.etc.
And now, the 6.2 GM stuff is starting to surface..... AARRGGHH!
With the trq you'll make, part throttle effect will not even be noticed.
That beign said, maybe these heads are total overkill for what I want to do,maybe they aren't... the original point was to see if they are flowing teh advertised #'s, which apparently they are, which is good to know. Might still do them, might not. I wonder how the 225 ET's woudl be compared to teh 225 AFR's? I knwo plenty of people have had good luck with box stock AFR's on 402/208 motors, I wonder how the ET 225's would be in comparison?
