Patriot Heads
Old Apr 8, 2006 | 11:10 AM
THEE PEWTER Z™'s Avatar
Default Patriot Heads
Good Or Bad --- Need Info For Na Ls1
Old Apr 8, 2006 | 11:24 AM
PREDATOR-Z's Avatar
Patriot has stepped up in their product quality. Gunnar is killer with customer service.
They are one of the best bang for the buck.
If you get aftermarket valves, then go for the Ferrea option.
Old Apr 8, 2006 | 12:46 PM
Ksett's Avatar
If you decide on this brand only get the 243 LS6 casting and you should be fine. Also I've heard good things about their customer service as well.
Old Apr 8, 2006 | 12:55 PM
Predator's Avatar
If you were smart, and you appreciated the value of a dollar, you would go Patriot.
The LS1 community is lucky to have this option.
Old Apr 8, 2006 | 02:16 PM
SVT THIS's Avatar
How are the 5.3 Stage 2 heads they have? I can get a set with arp head bolts for 625 to my door-should I do it?
Old Apr 8, 2006 | 03:25 PM
Threesixes's Avatar
Im happy with my set of stage II Ls6 Patriots.....
Old Apr 9, 2006 | 08:38 AM
GENIII's Avatar
Header bolt holes, water jacket paper thin six of mine leak.
Head gasket surface not flat, needed to use a whole can of copper spray to stop coolant leaking, still not fixed. this is on a new decked iron block.
Pushrod holes, all have 2 holes joining in the middle like a number 8.
Am I happy
Old Apr 10, 2006 | 08:42 AM
Gunnar@Patriot's Avatar
We have several options we can offer you. We can do a set of 5.3 heads, our LS6 style heads, or a set of our CNC ported 243 castings. Please give us a call or PM us and we will be glad to make a suggestion for your setup.
Old Apr 10, 2006 | 08:48 AM
777's Avatar
777
Why is this. You are limited to only one chamber size this way, and they don't flow any different as far as I know.
Old Apr 10, 2006 | 08:52 AM
Z'mnypit's Avatar
Am I happy
Hmmmm, got there stage III heads on my 408ci & I havent had the first issue. Ive also had their heads on my stock block with no issues. Whats wrong with the header bolt holes? Head gasket surface not flat?
Maybe you need to contact gunnar.....
Old Apr 10, 2006 | 09:56 AM
GENIII's Avatar
New patriot heads 8 weeks ago, new decked block everything new, put on header studs finger tight then placed on nuts finished both sides started new motor and after awhile water was leaking out everywhere, had to use RTV sealant in 6 holes to seal it, will see if the copper spray has worked on the other coolant leaks on head gasket surface. My concern is whats the deal with the multiple holes in the heads for the pushrods.
Old Apr 10, 2006 | 10:35 AM
Rescue Ranger's Avatar
I bought em'. Made good power. Customer Service is awesome.
Old Apr 10, 2006 | 11:14 AM
Z'mnypit's Avatar
Your leaks wouldnt have anything to do with the cometics would it? Ok, so whats wrong with the header bolts, if they are only finger tight then thats why they leak. The extra holes in the heads are for aftermarket rockers.
Old Apr 10, 2006 | 11:27 AM
mhoglund's Avatar
Iv'e got a set of stage 2's, couldn't be happier
Old Apr 10, 2006 | 11:41 AM
GuitsBoy's Avatar
He said header studs. The studs were probably finger tightened, but im sure he meant the nuts were torqued afterwards.
Old Apr 10, 2006 | 11:51 AM
GENIII's Avatar
So your saying that the most expensive gasket around cometics have a problem sealing intresting. finger tight as in studs done up the way they should be, put headers on then the nut, no they should not leak coolant at all regardless of how tight, the point is that the water jacket behind the stud/bolt on my heads where that thin after torqued down poped into the cavity of the heads using very little pressure and yes used the correct ARP stainless studs.
Old Apr 10, 2006 | 12:39 PM
Z'mnypit's Avatar
Yep, do a search Ive seen threads in here were people are having issues with them sealing. I see what your saying on the studs though, even though Ive never had that problem before. Good luck with your problem. Like I mentioned abouve, have you contacted gunnar?
Old Apr 10, 2006 | 06:36 PM
davered00ss's Avatar
Moderator
Cometics do leak. I had that problem on a New LS2 402 from SDPC with new AFR heads a friend and I did in his Z. New GM gaskets, then later, new felpro for more compression (sp) and no leaks with either gasket.
Old Apr 10, 2006 | 09:48 PM
777's Avatar
777
Calm down man, cometics are known to leak. It's the price you pay for a tight quench. Make sure you have all your ducks in a row before you start bashing a company. Nothing makes people look more stupid. Not that I'm calling you that, it's just that I think it's wrong for people to start complaining at the first sign of trouble, before they do some research or troubleshoot.
Old Apr 10, 2006 | 09:51 PM
Ksett's Avatar
Look at some of the combos and what they are making with the other heads and you decide for yourself.
