What Oil Filter To Use? AC PF59 discontinued?
Old 06-04-2006, 08:08 AM
1baddls1's Avatar
Originally Posted by windshear
Another vote for the M1-206.
and another!!!
Old 06-04-2006, 08:15 AM
INMY01TA's Avatar
I guess I'll be trying the PF 61 this time.
Old 06-04-2006, 08:19 AM
00transamnh's Avatar
FRAM its just an oil filter for christ sake
Old 06-04-2006, 08:21 AM
INMY01TA's Avatar
Most people on here will tell you they wouldn't use a Fram oil filter on their lawn mower. Maybe just a filter, but connected to just your engine.
Old 06-05-2006, 06:20 AM
Patman's Avatar
Fram filters are junk, they use cheap cardboard endcaps and cheap glue to hold them together. I wouldn't want one of those filters to go on a regular engine, let alone a high performance one.
Old 06-05-2006, 06:32 AM
Hardtop's Avatar
I use Purolator Pure One filters. They are a little cheaper than M1 or KN.
Bruce
Old 06-17-2006, 12:13 AM
2002B4CCamaro's Avatar
I was working with a GM World Class Tech this week while in Training for my new job and he has an LS1 in this Race Truck. He said DO NOT use a PF 61 on our motors. The thread pitch is wrong and when the filter is 1/2 installed you can wobble it back and forth. Can cause the threads to strip.
Also......While in the parts room I noticed that SAAB uses a PF59C filter. I am going to try one on my new oil change next month and see if it works..........
Old 06-17-2006, 07:55 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I also use the longer AC filter (PF 61; I think). No problems here
Old 06-17-2006, 10:04 AM
INMY01TA's Avatar
[QUOTE=2002B4CCamaro]I was working with a GM World Class Tech this week while in Training for my new job and he has an LS1 in this Race Truck. He said DO NOT use a PF 61 on our motors. The thread pitch is wrong and when the filter is 1/2 installed you can wobble it back and forth. Can cause the threads to strip.
QUOTE]Thats odd cause others here say they used it.
Old 06-17-2006, 10:18 AM
ls1muscle's Avatar
HP2006 + 6 quarts
Old 06-17-2006, 10:22 AM
ocshaman's Avatar
If you just want a filter, then use a Supertech, don't waste your money on a FRAM.
Old 06-17-2006, 10:48 AM
  #32
cenTX-LS1's Avatar
I run 6 quarts with my K&N 2006.
Old 06-17-2006, 12:40 PM
  #33
[QUOTE=INMY01TA]
He said once installed, it sits flush and tight, but just that slight angle can cause it to cross thread VERY easily.
Just my .02, if it works for you, go for it! Its just not something I want to risk on my car.
Old 06-28-2006, 06:46 PM
  #34
INMY01TA's Avatar
Just finished doin my oil and used the PF61. Fit just fine.
Old 07-03-2006, 08:14 AM
  #35
chevygirl's Avatar
What makes using a long filter better? I am using the short one M1 but I am thinking about going to a ac delco or K&N. Should I go long or short and why? I am going to get some of the 5-40W amsoil as soon as I can find it. I live in memphis tn and have not found somewhere to get it yet.
Old 07-03-2006, 05:54 PM
  #36
ocshaman's Avatar
A larger straw will flow more fluid at the same pressure rate, or it will flow the same amount of fluid at a lower pressure. With more surface area you have the ability to get more fluid filtered at the same pressure.
Old 07-03-2006, 09:52 PM
  #37
1936FordPU's Avatar
Ive been using them since they switched part numbers. Never once have had an issue. If you cross thread an oil filter, you shouldnt be working on cars or chainging oil in my opinion. LMAO
Old 07-04-2006, 12:33 AM
  #38
thunderdan74's Avatar
Bruce
Ditto, using the truck part number. I use to do the truck filter on my old SBC 406 too. One of the oldest tricks in the book.
Ignore that tech rep. The threads are the same.
Quick Reply: What Oil Filter To Use? AC PF59 discontinued?
