TR Cam Recommendation
Old Apr 9, 2006 | 04:24 PM
Hemi Killer's Avatar
14 Second Truck Club
Default TR Cam Recommendation
I got a cam recommendation back from thunder racing the other day for my 383 LS1 build-up. Here is the specs:
1999 Chevy Silverado Ext. Cab
383 LS1(4.000" Eagle Crank/6.125" Scat I-Beams/undecided on Pistons)
5.3 Patriot Performance Heads (Stage 2)
3.90 Gears/Eaton
2600 Yank Converter/Beefed-up 4L60-E
Full Bolt-ons
Dyno-Tune
They said to stay on the smaller side since I occasionally tow and being my daily driver. They said to go with a 224/228-110 on a XER lobe. I was kinda wanting to go a little bit bigger than that. What do you ya'll think?
Old Apr 9, 2006 | 04:29 PM
gollum's Avatar
I like it. It would make lots of stump pulling torque and good horsepower to move your heavy truck.
Old Apr 9, 2006 | 05:13 PM
What about the top-end? Like from a roll would I have a chance at a stock Lightning or SRT-10?
How does it do in your car? Where does the hp and torque peak at? When do you shift? Thanks!
Old Apr 9, 2006 | 05:27 PM
gollum's Avatar
I shift at 6000 rpm but the cam will easily rev to 6800rpm. Yes, your heavier pickup will easily outrun the stock Lightning But you may need a 3.42-3.73 gear for better top end.
My horsepower peaks at 6250 rpm
Old Apr 13, 2006 | 05:13 PM
I'm really thinking about getting this cam. Does anybody have any suggestions on maybe a different cam?
Old Apr 13, 2006 | 06:38 PM
brad8266's Avatar
3.90 Gears/Eaton
Full Bolt-ons
Dyno-Tune
That is a good grind for lots of touque down low. There is a very long thread about a cam of this size in thus forum, its like 8 pages long, check it out it was a lot of info in it.
Old Apr 14, 2006 | 02:03 AM
Yeah, I seen that. I'm curious of the dyno #s in a 346. What do ya'll think it would do in a 382/383? I'm thinking something like 425-440rwtq.
