LPE Cam/Head Install
Old Apr 10, 2006 | 03:04 AM
SS_Hokie's Avatar
Default LPE Cam/Head Install
Ok so I bit the bullet and bought Lingenfelter's cam/head combo. The cam is the LPE GT3-2 and the heads are LS1 CNC ported and polished. I am also installing a Max Flow Mass Air Sensor and a 1030 cfm throttle body. I think it should be good for around 80 horses. The motor is bone stock besides an SLP air lid.
A few questions:
For head bolts, should I spend the 100 bucks on ARP head bolts or will 40 bucks for GMPP be ok?
Head gaskets - I know there is much talk about the thickness of the gasket, but when it comes down to it, if it seals and lasts, I'm good.
I have a McCloud clutch/PP/FW from a C5 M6, will this bolt directly to my M6?
I can reuse the stock lifters, but come on, after all this work, I don't think so. Any advice on a good set of lifters and rocker arms?
One last question, LS2 timing chain, yea or nay? I have read that in order to use a double roller, some milling has to be performed for clearance issues.
Any feedback will suffice as this is my first chevy mod. I was a 5.slow man for years and had fun with it, but I saw the light and bought my 2001 SS.
Thanks guys
Old Apr 10, 2006 | 07:02 AM
Quik's Avatar
do you mean the GT2-3? if not then what are the specs on the GT3-2. i run the GT2-5 in my LQ9. i also run the LS2 tming chain. as for head bolts the first time i did my setup i used GM head bolts this time around i dunno yet
Old Apr 10, 2006 | 09:03 AM
PREDATOR-Z's Avatar
Stock bolts are fine
GM MLS gaskets
LS2 Chain super
Comp 850-16 for lifters
7.40 Comp cam push rods
And of course a tune (that is 1/2 the power of your swap)
You didn't mention anything about headers?
Old Apr 10, 2006 | 01:33 PM
AJay's Avatar
Old Apr 10, 2006 | 02:22 PM
SS_Hokie's Avatar
It is the GT2-3, my bad, typo at 2 in the morn.
Old Apr 10, 2006 | 02:29 PM
AJay's Avatar
Chris,
Please post your results after you do your install and tune. I'm thinking about the same set up for my Vette.
Old Apr 10, 2006 | 07:53 PM
Quik's Avatar
seems like the SSS guys with Radix's like that cam for boost. i remember reading an article about that cam in a 5.3 and it produced some nice numbers. its a very stealth cam with a 118.5 lsa or it might just be 118.
Old Apr 11, 2006 | 12:17 AM
SS_Hokie's Avatar
You are correct, the LSA is 118.5. I'm psyched about this install. Buying all the misc. parts for the install now. Gotta love the misc. parts.
 Michael S. Palmer
Old Apr 12, 2006 | 07:36 AM
BanditTA's Avatar
Originally Posted by AJay
Chris,
I was thinkiing the same exept use their LS6 CNC ported (aka GMPP heads). I was leaning more towards the GT-11 cam but could always go back to the GT2-3. LPE said with the GT-11 & GMPP heads with stock manifolds and the usual bolt ons i could hit 400 rwhp or pretty close and still remain pretty driveable.
Old Apr 12, 2006 | 06:45 PM
Greg_E's Avatar
I have the LPE GT2-3 cam, GMPP LS6 heads (milled.055") LPE LT headers, stock cat's,LS6 intake manifold ported TB and Blackwing. 403HP/381TQ. Other than some slight valvetrain noise you cannot tell the difference from stock at idle. It is pretty much the ultimate stealth package, if that's what your looking for.You could go with a bigger cam, still have good driveability and
more HP.
Old Apr 12, 2006 | 07:32 PM
SS_Hokie's Avatar
That's pretty much what I wanted to go for. How did the LPE LT's work out? Any clearance issues. I have a 2001 SS, with the eibach kit. May not be a question that you can answer.
Old Apr 12, 2006 | 07:42 PM
Greg_E's Avatar
Clearance is not an issue.('99 C5) I bought these some time ago. I don't think LPE even sells them anymore. There are better flowing headers now.
Old Apr 13, 2006 | 02:42 AM
SS_Hokie's Avatar
I guess I'll go with everyone else and get the Pacesetter LT, seem like they are the best bang for the buck. I have been reading that many people experience their Y-pipe banging, but I think I read that Mufflex offers bump stops for your Y-pipe. Can anyone verify this claim? Guess I need to do the research myself.
Old Apr 13, 2006 | 02:48 AM
SS_Hokie's Avatar
Yep, found it
http://www.mufflex-performance.com/home.html
If anyone has used this, please let me know of its performance
Old Apr 13, 2006 | 07:45 AM
BanditTA's Avatar
more HP.
Wow thanks, i've looked all over for somebody with that package, Thanks for the input. I probably will not put headers on mostly because i want it to appear stock and i've never had good luck with headers (cracking,leaking,rusting,coming lose etc.). Who did your tune? Or is it tuned? Thanks
Old Apr 13, 2006 | 05:03 PM
Rob's Avatar
Rob
I'm running the GT2-3 with GMPP LS6 heads but with 65cc. Dynatech long tubes with cats into the stock catback, SLP pulley, Speed Inc CAI, and tune. I didn't put the ported TB on until after it was tuned but it should be ~400rwhp now.
Parking mine next to a stock GTO and you couldn't tell the difference at all
Old Apr 13, 2006 | 07:12 PM
eamador11's Avatar
more HP.
i agree, youll be regretting not going with a bigger cam. trust me. i started with a 220/220 cam and after 1 year, i had to upgrade to a 224/228. You want a cam you can feel.
My car is still smooth close to stock.
Greg_E's Avatar
Vette Drs. on Long Island did the install work and tune.
