Ticking Noise LS1
Old Apr 10, 2006 | 11:21 AM
mhoglund's Avatar
Default Ticking Noise LS1
I've got a 2004 GTO and I had the heads and cam swapped out. The car also has Stainlessworks headers and a Bassani cat back. With the hood open everything sounds fine. But from under the car I have a ticking noise coming from what seems to be both sides. When its cold its louder, when its warm it quiets down a bit, but is still noticable, especially when I'm next to a building. The cam is the Vinci 056 cam and I used the 1.8 rockers. The car had 7000 miles before it was modded and now has 8400 miles. Any suggestions?
Matt
Old Apr 10, 2006 | 11:46 AM
Grimes's Avatar
are your header bolts tightened down for sure?
Old Apr 10, 2006 | 11:48 AM
mhoglund's Avatar
I will double check them again, but yes I believe they are tight. I used locking header bolts, not the stock ones.
Old Apr 10, 2006 | 01:13 PM
tails8's Avatar
Most LS1's will have a ticking/sewing machine sound after a H/C swap. I know mine did afterwards and it scared the **** outta me.. It's the nature of the aluminum block and the composite (plastic foir the ol timers) intake..
Tails
Old Apr 10, 2006 | 01:20 PM
MICAH HERRON's Avatar
From: Johnsonville, SC; but orginally from GAINESVILLE, FL
Tails
I agree, but it sounds like you have an exhaust leak somewhere. What is your oil pressure.
Micah
Old Apr 10, 2006 | 01:25 PM
Torque_Wrench's Avatar
Hey bud....mine does the same thing! My problem was the belt tensioner.
Old Apr 10, 2006 | 01:52 PM
HASTINGSRJ's Avatar
My valve train is noisey as hell....ticking etc....runs fine though....but then again I do have 921 springs
Old Apr 10, 2006 | 03:26 PM
dedge's Avatar
I have the 062 VHP /duel springs/titanium retainers/ pushrods all bought as package deal. Mine does the same thing. I have the supermaxx system but I think this is the sewing machine sound everyone talks about.
 Michael S. Palmer
Old Apr 10, 2006 | 07:56 PM
Quik's Avatar
Tails
its not just the aluminum blocks. my LQ9 is noisey, i was worried it was something major then heard other cammed Gen III motors and was releaved
Old Apr 10, 2006 | 08:06 PM
mhoglund's Avatar
Sewing machine noise on top with the hood open, yes I have that. However the noise I'm talking about is coming from under the car. Its kinda ,loud when its cold, after it warms up the sound changes a little, it almost has a bit of a higher pitch, but its still a ticking noise. I'm taking it to get it checked out tomorrow.
Old Apr 10, 2006 | 08:27 PM
jub jub's Avatar
Believe me, it's normal and is more pronounced with big cams.
Old Apr 10, 2006 | 08:32 PM
Quik's Avatar
noise from under the car and its not a sound of leaking gaskets could be a bearing on its way out
Old Apr 10, 2006 | 09:03 PM
brad8266's Avatar
Piston slap
Old Apr 10, 2006 | 09:08 PM
VTC_WS6's Avatar
Lifters..
Old Apr 10, 2006 | 09:20 PM
DocEwww's Avatar
Originally Posted by brad8266
Piston slap
Thats what I say also.
1. comming from underneath (not lifters)
2. Louder when cold (exhaust leak wouldnt do that)
With 8400 miles?
Old Apr 10, 2006 | 09:27 PM
Quik's Avatar
With 8400 miles?
yep seen a motor fail after 100 miles. the machine shop installed the cam bearings wrong and didnt clean the oiling holes so it starved the cam of oil and caused the bearings to become toast and then had shavings in pick up screen causing it to lose oil psi. it sounded normal at first then it got worst and worst as miles were put on. 100 mile mark was it for that motor
so its possible, the bearings might of not liked the cam and spun the bearings some
Old Apr 11, 2006 | 12:21 PM
tunedportcj5's Avatar
Make sure ALL of you sparkplugs are torqued down. A loose plug is the definition of your problem. Good luck
