6.0 v8
Old Apr 10, 2006 | 06:22 PM
98redtransam's Avatar
Bad Trader Investigation in progress
Default 6.0 v8
i bent a rod in my ls1 that was in my ta. i found a 6.0 out of a sierra and was told it was an ls based motor. i know i will have to change the heads, oil pan, intake but was wondering if it really was an ls based motor and if my computer would work with this motor. any help with and i thank you.
Old Apr 10, 2006 | 08:28 PM
Quik's Avatar
the motor you found is an LQ4 motor. the heads on that motor as long as they are the aluminum ones are better flowing then your current stock heads. the casting is 317 and have same flow rates as the LS6 heads. only difference is the 72cc compared to the 65cc in the LS6 heads. i have them on my LQ9 motor. the cam is very similar to the cam in the early Y bodys. your pan and everything will bolt up to it. but you will have to drill and tap the one provision for the ALt bolt. its nothing major at all. i did it to mine when i used Fbody accesories for my truck. and yes all parts for your LS1 motor will work for that one. except your current heads. your motor i do believe has perimeter bolts where as 99 and later blocks had center bolts. as for the computer it will fire and run that motor but would optomize if you got a tune. also the CR on the LQ4 is about 9.5 and the CR on your LS1 is 10.1
Old Apr 10, 2006 | 08:43 PM
thanks for the help. so basicly i can put this motor in my trans am with no problem just have to use the heads on the motor instead of the ones on my car right? i have a comp cam .561/.567 lift that i was going to install. it will still fit in this motor without any problems right? also, the lower compression rate a plus or negative as far as power and performance. the motor has 22000 miles on it and the guy proved to me it ran and only wants $500 for it and a 2 year warranty. overall seems to be a good deal just had some questions. thanks.
Old Apr 10, 2006 | 08:57 PM
Quik's Avatar
i run a LS1 cam in my LQ9. its a 566/566 lift and no issues
only factor youll have is the added weight of the motor. since its and iron block youll gain about 80lbs up front. so the front will sag some. give you a rake effect. as for the lower CR youll only lose about 15hp honestly and youll gain that with a cam. if you had a 99 and later block you could use your heads but the 317s are a better head. if you wanted to you could just shave some off but becareful with an GenIII P to V clearance issues. for 500 bucks thats a good deal. just make sure its a 317 head motor.
Old Apr 10, 2006 | 09:27 PM
i looked on the heads and couldn't find the casting numbers. manifolds and everything is still on motor so could have missed it. is there any castings that is just a don't buy it?
Old Apr 10, 2006 | 09:31 PM
Quik's Avatar
well simple thing to look for are the heads aluminum or iron? if aluminum they are 317s. if iron then i would look for a set of aluminum heads.
and casting number is on passenger side front of head. its behind where the ilder is. also on the back of the driverside head.
Old Apr 10, 2006 | 09:37 PM
stock heads off my ls1 would work if iron. ok thanks for the help. do believe 317's. thanks again.
Old Apr 10, 2006 | 09:46 PM
Quik's Avatar
97 and 97 heads are perimeter heads and not sure if they would bolt up to that block. [keyword not sure, never experienced it]
and if they are the 317s use them
Old Apr 12, 2006 | 11:26 AM
GTA91's Avatar
So can you use '98 LS1 heads on a 6.0 iron block?? I'm assuming you can and you just have to use the head bolts for a 6.0 and the head gaskets for a '98 LS1.
Old Apr 12, 2006 | 11:50 AM
Mater's Avatar
yes they will but your better off with the 317s
Old Apr 12, 2006 | 12:03 PM
n2o junkee's Avatar
Thanks I am currently going from a stock bottom end to a 6.0 forged and a lot of my questions were answered. thanks again BUT i DIDN'T GET MINE FOR $500. great deal
Old Apr 12, 2006 | 12:21 PM
BES Stroked Nova's Avatar
****, thats what i am looking for...... my car just started to rod knock...
Old Apr 12, 2006 | 01:03 PM
yeah everything was included for a full pull out. i have to use my altenator, starter, intake everything else is the same. it hase cast iron heads though. i have to use my ls1 heads. other than that perfect match.
Old Apr 12, 2006 | 01:16 PM
what size injectors are in the LQ4. same as stock ls1 or should i put mine from ls1 in the LQ4?
Old Apr 12, 2006 | 01:19 PM
GTA91's Avatar
probably not... I doubt stock 317's flow better than my ported '98 heads
*Also, what is this talk about iron heads on the 6.0?? I thought they all had aluminum 317s??
Old Apr 12, 2006 | 06:53 PM
Quik's Avatar
early LQ4s had iron heads. in 01 they swapped over to aluminum along with increase in power
317s stock are the same flow rates as 243s so if you flow more then LS6 heads then yes use yours if not then use the 317s
injectors are 25s
Old Apr 12, 2006 | 07:09 PM
correct me if im wrong but doesn't a stock 98 TA come with 28lb injectors
Old Apr 12, 2006 | 07:15 PM
GTA91's Avatar
I think they are 28.8lb but I'm not 100% sure.
Old Apr 12, 2006 | 07:17 PM
Quik's Avatar
i htought the later year LS1s had the 28s and the earlier ones used the 25s
and with my statement the 6.0s use 25s
Old Apr 12, 2006 | 07:51 PM
Mater's Avatar
yes they are!
