Connecting Rod question...
Old Apr 10, 2006 | 09:53 PM
TheBowtieboy's Avatar
Default Connecting Rod question...
I see that most of the connecting rods out there are in the $450+ range....until I read about a set on SDPC.
It's a Scat I Beam -
4340 forged steel I-Beam 6.125"
Average rod weight is 590
Full Floating bronze bushed pin end, fits 0.927 diameter pins
Premium ARP 3/8" cap screws
.....cost is under $300.
.....to be used on a stock to mild cam car (330-360 RWHP) to only be
ran up to 6200-6400 RPMs limiter (max).
What are your thoughts ?
Old Apr 13, 2006 | 07:27 PM
bichin95redta's Avatar
Pretty good price for a Scat forged rod, but what the heck do you need something that stout for? OEM rods are perfectly capable of handling the HP/revs you're talking about.
Old Apr 13, 2006 | 07:49 PM
GuitsBoy's Avatar
Like teh man above said, you dont need to forge for those kind of revs and power.
Old Apr 13, 2006 | 09:10 PM
Thanks for the responses...
Old Apr 13, 2006 | 11:22 PM
Michael55123's Avatar
Lets assume I have a H/C car, and want to run a 200 shot? How are these I-Beam rods. Anyone running them? For 300 bucks I'd pick them up, but that's only because I have a bent rod.
Mike
Old Apr 15, 2006 | 10:53 PM
Mike
A bent push rod or connecting rod ?
......the stock push rods will bend pretty easily with a heads/cam and bumped RPM's.
