cam install -- is new crank/cam gear needed??
personally if the gears arent worn[judging by the teeth like any type of sprockets] you should be fine. just toss on a LS2 timing chain and call it a day or you could go the route of buying a double roller TC which comes with sprockets and have fun with that. personally i went with the LS2 in my LQ9 and it had 42k on it
