Backpressure issues, what's next???
Old Apr 12, 2006 | 08:36 AM
Quatney's Avatar
Question Backpressure issues, what's next???
What do you think the next step should be on my setup?
Heads/Cam or Intake/Throttle Body?
Car:
2000 SS
Edelbrock Victor Series Headers
Custom dual 3" exhaust dumped
SLP Lid
I want to eventually put a Procharger on the car, and will probably get a lot of internal engine work done. I'm shooting for around 600HP or so, but this is way down the line. I obviously don't have much done, and yes I know that this exhaust was way overkill for what I currently have. But I refuse to buy something I know I'll replace later, with in reason .
I've read all of the FAQ's on Cam's and believe I have a better idea of the "overall workings" of them, but I'm really not sure what would be a good Heads/Cam setup for me if I wanted to put a Procharger on my car.
I'm assuming there are better setups specifically for forced induction that I should go with, but would those setups run "okay" without the forced induction until I can afford it and would they run okay with the current compression of the car? The Heads are something I've come to realize I'll have to replace if I redo the engine to lower the compression (unless I'm just plain wrong, feel free to correct me) .
FYI: I know that this is not the next "best" modification as I don't have any suspension components or a good rear end. That will have to be something I look at soon, but this is just for future knowledge.
