Powerband of a Torquer2 on a 114?
Old Apr 12, 2006 | 10:00 PM
Wnts2Go10O's Avatar
Default Powerband of a Torquer2 on a 114?
so ive narrowed down the cam for the SS between two cams. the Torquer2 aka XER281 being much more likely. not too concerned with how itll sound but what kinda power curve id be looking at and such. ive searched and it seems no one has it on a 114. would it be uncharted territory or somethin? also if someone can, can i get the FULL specs of the cam? thanks guys.
Old Apr 12, 2006 | 10:24 PM
mcamp001's Avatar
I have a XER 230/230 on a 114 lsa 114 ICL, this may be close, you can find dyno charts here;
http://campione.org/car.htm
Old Apr 12, 2006 | 10:27 PM
1slowls1's Avatar
I'm assuming you havnt checked texas speed sit if you dont know the full specs, if this is what your asking 232/234 .595/.598 power band is 1800-6400.
http://www.texas-speed.com/shop/item...d=168&catid=44
Old Apr 12, 2006 | 10:40 PM
sledneck687's Avatar
I believe predatorz has that cam on a 113, and he siad it pulls strong all the way to 6800 when he shifts. So im guessing the 114 will be right around that area. 6800-7000. Also I believe it really kicks in abotu 3500 or so. Someone feel free to correct me if im wrong.
Old Apr 12, 2006 | 10:42 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I believe that you are correct and incorrect at the same time. His motor went bye-bye. But yeah, he is a great person to ask a question to about it!
Old Apr 12, 2006 | 11:01 PM
Wnts2Go10O's Avatar
not jus tht but basically the entire cam card
Old Apr 13, 2006 | 12:14 AM
HolyShiznit's Avatar
I have the Torquer V.2 on a 112+2. Definitively loss of torque from idle to 1900. Past that though it gets wheelspin. I feel the car start to pull around 2500. Past that and we are moving. It REALLY takes off around 4500. I haven't taken it to redline yet because quite frankly by the time I catch traction I am going way to fast. I took it to 6grand today and I was just FLYING.
This is on a 6 speed with stock gears btw.
Old Apr 13, 2006 | 12:45 AM
Wnts2Go10O's Avatar
im jus wondering wht the 114 will do. or if the only difference would be a smooth idle
Old Apr 13, 2006 | 12:55 AM
co.6z28's Avatar
not all that much. i have this cam on a 112. i am making peak power at 6500. why do u want it on a 114?
Old Apr 13, 2006 | 01:50 AM
Wnts2Go10O's Avatar
it aint gonna be NA forever and a 114 would make it more friendly for what we wanna do. it wont be the perfect cam but it wont be anywhere near the worst either.
Old Apr 13, 2006 | 05:21 AM
1slowls1's Avatar
I was goin to go with the torquer 2 but reading what people had to say to make it work good i needed to flycut my pistons etc. it just sounded like too much work so i talked myself down to the 228r from texas speed 228/228 .588/.588 at 112lsa
Old Apr 13, 2006 | 12:53 PM
Wnts2Go10O's Avatar
flycutting with a 230 cam tht isnt even 600 lift? you mean with new heads?
Old Apr 13, 2006 | 01:06 PM
GuitsBoy's Avatar
You can only mill about .010 with this cam. I notched the pistons and milled the heads .040 and im loving it.
Old Apr 13, 2006 | 03:49 PM
Wnts2Go10O's Avatar
well, if anything the chambers will get bigger...
Old Apr 13, 2006 | 05:10 PM
nokeman's Avatar
You definately wont need to fly cut the pistons with this cam...unless you have other-than-stock heads.
Old Apr 13, 2006 | 09:05 PM
Wnts2Go10O's Avatar
anybody with it on a 114? although i appreciate the info form those that have the cam although on different lsa'a
Old Apr 14, 2006 | 12:36 AM
gus99ssm6's Avatar
i got this cam on a 114, i love it. and its not even tuned yet, i get my tires spin at 3500, it kicks in at 2000 rpm, all the way to 6000rpm it cuts off until i tune it .6600rpmis the goal, it pulls hard when your able to get traction anyway, look at the bottom you'll see what i have, Nice cam in my opinion. I been driving it for 2 weeks without a tune, went to los angeles from las vegas and back. PM if you have any questions.
Old Apr 14, 2006 | 08:20 AM
Patrick G's Avatar
LS1 Tech Administrator
The T2 will be pretty lazy in mid-range torque on a 114LSA unless it has 4 degrees of advance ground in. Even with +4, the intake valve closing point is 46 degrees ABDC. If you get in on a 114LSA, just make sure to get it ground +4, otherwise you'll need to call the cam something other than the Torquer.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
