Another cam ?
there is a huge thread on cams around if you feel like searching. but i think i know the answer to your question.
a bigger duration cam will make bigger power, but the bigger the duration, the higher up in the rpms the power will come. for example a 224/224 cam on a lsa will make power from idle all the way up, but not tons of power. a large cam
like the texas speed giant 248/254 will make tons and tons of power, but the power probably wont kick in until 4000 rpms, if you let out the clutch like normal the car would stall. if your car is auto it wouldnt even drive with the stock stall converter. that is about .001% of what there is to know about cams, but i hope that helped
