F13 vs 228R
Old Apr 15, 2006 | 11:11 AM
ninobrn99's Avatar
i cant email it cause its 13mb. i cant upload it here on tech or yousendit. ill see if i can shrink it so i can make it smaller. sorry..its a good clip too
Old Apr 15, 2006 | 11:12 AM
RoastEmSS's Avatar
K man id really appreciate it
Old Apr 15, 2006 | 11:37 AM
FUN LS1's Avatar
Originally Posted by M6WS6
IMHO, lope =
I went f-13....
Can't agree more, except that if you're thinking about the F13, you can get a meaner lope from the F14. All three of these cams would benefit from taller gears (I'd recommend 4.10's, but 3.73s would work and might be stronger), and with the gears the F14 would be just as 'streetable' as the other two. (So would the TSP 233/239 112+4, but I don't want to confuse the issue...) Check out this F14 video from LS1sounds:
http://ls1sounds.com/headers_cutouts..._fm14-idle.wmv
Old Apr 15, 2006 | 11:45 AM
RoastEmSS's Avatar
Trust me ive watched it 1000 times only reason i dont want FM14 because the peak power is too high and it doesnt have near as much down low as the 228R and yes 4.10s will be coming very soon
Old Apr 15, 2006 | 11:51 AM
FUN LS1's Avatar
I hear you, and I think you can get about 415 rwhp from the 228R with your setup and a good tune. At an F-Body shop in Central MD, I saw an '00 SS w/out LTs make 396 rwhp in the hands of good tuner. With 4.10's you'll always be in the power band
Old Apr 19, 2006 | 12:54 PM
okls1's Avatar
Are you guys running dual springs with the 228r? Wouldn't it be harder on valvetrain since it has xer lobes where the f13 supposed to be not too harsh? I was thinking about f13 but my car is dd and mostly street car so maybe the 228r would be better? thanks
Old Apr 19, 2006 | 01:02 PM
STRIPSTAR's Avatar
i have a clip, but its with duals and i dont have anywhere to host it. send me your email and ill try to send it to you. mine was on a 114 also. The point of a cam isnt for the sound, its for the gain. if you want sound, get a cam with more overlap and a low LSA.
what he said
Old Apr 19, 2006 | 03:24 PM
my01camaroz28's Avatar
I am running comp cams 26918 springs (.600) on my 228. No problems yet. I will check the spring height in about another 10,000 miles.
Old Apr 19, 2006 | 09:39 PM
SVT THIS's Avatar
So the 228R is the best for a daily driver? Mine won't be a track car, mostly stop light and highway racing. I actually don't even race, more or less stomp it on the on ramp or on rural roads for my own enjoyment.
I am running a 4000 stall converter and will have 3.73 gears. People have steered me towards the 228r, but with my stall and gearing would I not see more benefit from the MS3 or F14 on a 112 LSA?
I am upgrading my lifters, pushrods, using dual springs, double roller timing chain, ls6 oil pump and 5.3 stage 2 heads, so I'm not going to be worried about revving to 6800rpms. Would the 228r still benfit me more than an MS3 or F14?
I'm not trying to hijack the thread, just trying to get as many opinions as I can on what cam would work best for me.
Old Apr 19, 2006 | 09:46 PM
Kraest's Avatar
Yes, boys and girls:
The more duration, the longer you have to wait for peak horsepower/torque on a 346.
Mike
Old Apr 19, 2006 | 09:48 PM
DEVIATE's Avatar
Mike
Thank You
Old Apr 19, 2006 | 11:56 PM
  #32
Ryne @ CMS's Avatar
LS1TECH Sponsor
well my ls2 with fast 90, 232-234 comp xer (torquer2), i made 447 rwhp, 426 rwtq, but i have 243 heads, and 18 more cubic inches. but from what i am seeing cams with 235+ duration, arent really making enough power over smaller combinations, to justify the crappy drivability. i think i wouldnt go any larger then 232 duration cam on the street, but thats my own .02 cents
Old Apr 20, 2006 | 07:08 AM
  #33
slow trap's Avatar
i used comp 918s also.
Old Apr 21, 2006 | 09:05 PM
  #34
99zman's Avatar
my first cam was the f10. I loved it. I thought I wanted bigger so I went with the f13. I dont have the low end grunt it used to have. The torque was really nice! with the f10 114 i put down 377/372 and with the f13 112 and ls6 heads i put down 396/366. The tune isnt on point at all for the f13 and i expect it to be much better once i tune it, but i feel i should've stuck with the f10. I guess i just jumped on the band wagon because I was impressed by the peak numbers everyone was posting. That made me stray from my original goals of having streetable power..the f13 was still pulling at 6700 If your not going to spend alot of time at the track or in the high rpm range, id go with the 228 112.
good honest info, im in the same boat trying to decide?
Old Apr 26, 2006 | 12:01 AM
  #35
Phil'sC5vette's Avatar
Mike
best put
Old Apr 26, 2006 | 02:49 AM
  #36
cantdrv65's Avatar
Thumbs up
IMHO 228/228 XER is damn near the perfect street car cam... I love mine! and yes it lopes very nicely at 850rpms....
