prc dual springs
Old Apr 14, 2006 | 09:08 AM
Cam72aro's Avatar
Default prc dual springs
I have a 2000 ls1 and am wanting to do the trex cam and prc dual valve springs. My question is, do I have to machine the spring seats in the heads for these springs?
Old Apr 14, 2006 | 09:23 AM
BIG_MIKE2005's Avatar
Not that I know of. I just bought a PRC double spring & pushrod kit from TSP. Jon never mentioned it to me & we talked about it for a while before we decided it was the right kit for my cam. I'm very impressed with the quality of the kit also.
Old Apr 14, 2006 | 09:56 AM
99blancoSS's Avatar
You should call them, I dont think they are direct drop in replacements
Old Apr 14, 2006 | 10:07 AM
777's Avatar
777
They are. I've been running them for 20k miles. You have to get the kit w/ the ti retainers, as your stock retainers won't work. But there is no machining needed to the seat.
Old Apr 14, 2006 | 10:50 AM
Zach@Texas-Speed's Avatar
There is no machining involved with installing the PRC dual spring kit. I've have mine on the car for ~20k miles as well and still perform the same as the day they were put on the car. Best spring for the price IMO
If you guys needs some pricing on the kit, shoot me a pm!
-Zach
Old Apr 14, 2006 | 11:18 AM
Robinator's Avatar
TR told me with that cam (T-rex) you have to use a .030 shim with the dual valve springs.
Old Apr 14, 2006 | 11:31 AM
Cam72aro's Avatar
Default cam
What about running the ms3 cam with these springs?
Old Apr 14, 2006 | 11:53 AM
The MS3 has specs close to mine & I also talked to Jon for a buddy who was lookin @ the MS3 & he said this kit would work for it also. The kit is worth it, it comes with new locks, tit. retainers, pushrods, double springs, etc...
 Michael S. Palmer
Old Apr 14, 2006 | 12:23 PM
bigdsz's Avatar
I think those springs are good for a .650 lift and the tRex is .61X lift, but I would check coil bind FWIW, if you are shimming.
Old Apr 14, 2006 | 01:33 PM
Robinator's Avatar
PRC's are good to .660 lift
Old Apr 14, 2006 | 04:14 PM
Jon uses them on his .650 lift cam in his 408 and hasn't had any problems at all, no shims
Old Apr 14, 2006 | 10:13 PM
777's Avatar
777
I thought platinum's were .670 lift max. Anyhow they are a nice piece and will work perfectly for the cam
Old Apr 14, 2006 | 10:47 PM
Joker's Avatar
I daily drive these springs on a TSP 242/248 cam with .625 lift, no machining needed at all, great product at a great price.
Old Apr 15, 2006 | 07:17 AM
98A4LS1's Avatar
^^^ Same here, daily driver, no machining spring seats nor did I need to use shims. Nice kit for the price from TSP!
Old Apr 15, 2006 | 12:47 PM
john59's Avatar
Great Spring!!
Old Apr 27, 2006 | 04:06 AM
DocEwww's Avatar
bump...Ive heard this also. Is this a must with the Trex?
Old Apr 27, 2006 | 07:53 AM
GuitsBoy's Avatar
Like all the others said, great spring kit. Direct fit.
Old Apr 30, 2006 | 03:13 AM
DocEwww's Avatar
Bump. Is this a must?
Old Apr 30, 2006 | 03:36 AM
MiaSSmaro98's Avatar
good stuff no mods needed
Old Apr 30, 2006 | 09:52 AM
4mula's Avatar
great springs!
