View Poll Results: Which cam should I used with these heads and other mods?
228R
74
46.54%
TRAK
8
5.03%
MS3
64
40.25%
None of those! (suggest something)
13
8.18%
Voters: 159. You may not vote on this poll
228r or MS3
Old Apr 16, 2006 | 03:48 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I think that you are going to want a midrange cam over a high RPM banded cam with less lowend.
Old Apr 16, 2006 | 04:19 PM
SVT THIS's Avatar
Even with a 4000 stall and 3.73s? I thought that a good highend cam would work best with my stall and gearing.
I'm still debating the 228r, I keep seing awesome times with the MS3 and haven't seen a lot of impressive times with the 228r. I'm not saying its not possible, but if its so much better, why doesn't everyone run them and have times to brag about? I'm not ******* that cam, just trying to get some debate going to help my decision.
Old Apr 16, 2006 | 04:33 PM
CraZee ZO6's Avatar
Lot of people are saying that "people are overcamming these cars with ms3, g5x3 etc"
Than how come more tuners are coming out with bigger cams from there previous versions and going faster.
For example. Cartek usually runs smaller cam and gets it done, but they did come out with their new 4x cam (which is bigger) put more power on the dyno and proabably will go faster in the 1/4.
SO how does a 228r and ms3 car run the same. Doesnt make sense to me, I would think a ms3 car would walk on a 228r car.
Old Apr 16, 2006 | 06:44 PM
calongo_SS's Avatar
If it's set up properly it will.
Old Apr 16, 2006 | 07:24 PM
CraZee ZO6's Avatar
exactly...
So I wouldnt say people are over camming these cars. Bigger cam needs a few other things to shine. COMBO.
I think at 3k UP a MS3 car with the right combo will walk any cam smaller steadily.
Old Apr 16, 2006 | 08:35 PM
DEVIATE's Avatar
Keep in mind set up. heads, convertor, gears, slicks, etc etc etc. Just cause you have alot of horepower on the dyno dont mean **** when it comes to goijng down the 1/4. 415 rear wheel horsepower 400 lb ft 3200lb car. went 11.18 121. Not much horsepower plenty et. 2500+ da when that time was ran.
Old Apr 16, 2006 | 08:46 PM
RoastEmSS's Avatar
couldnt of said it better myself, peak hrspower isnt everything, by the time u are at 7,000 peaked with the ms3 i will already be gone peaking much faster and gettin to peak power much faster, ull chase me down in the long run, dont know if itd be within the 1/4 mile tho
Old Apr 16, 2006 | 10:12 PM
cws T/A's Avatar
go BIG or go home Ive got the MAGIC STICK
Old Apr 17, 2006 | 10:45 AM
SVT THIS's Avatar
Well the votes seem to be pretty neck and neck. Keep the opinions coming!
Old Apr 17, 2006 | 04:22 PM
CraZee ZO6's Avatar
Dont fear the gear, dont fear the LOPE!
haha
Old Apr 17, 2006 | 06:16 PM
cws T/A's Avatar
haha
Old Jul 3, 2006 | 06:51 PM
  #32
Phil'sC5vette's Avatar
My car is getting buttoned up right now with the 228R in ot with AFR heads. It should be fun. Actually the car was fun with the TR224 cam only, so im sure I'll be smiling
Old Jul 4, 2006 | 04:04 PM
  #33
SVT THIS's Avatar
Dead post. I went with the Trex cam. I bet your numbers will be awesome with the 228 and AFRs though!
Old Jul 4, 2006 | 05:10 PM
  #34
1slowls1's Avatar
233/239 cam from TSP, i was stuck on the 228r but i wanted to ms3 so i just went somewhere in between, still dont have my car back yet so ill let you know how i like it when i get it back.
Old Jul 4, 2006 | 06:46 PM
  #35
Sprayed1998's Avatar
Torquerv2
Old Jul 5, 2006 | 11:57 AM
  #36
RoastEmSS's Avatar
Originally Posted by Sprayed1998
Torquerv2
Old Nov 14, 2006 | 09:53 PM
  #37
erikthegoalie's Avatar
i looked at the 228R....but then..I looked at the MS3, one of the baddest well known cams to date....it really is(if set uo properly)....so i went for it....i have yet to install so I will not fill this post up with false hopes....but the good news is YOU CAN ALWAYS CHANGE A CAM WITH MINIMAL WORK (compared to a head/cam swap)....hell if its to high end change it!
My vote MS3
Erik
Old Nov 15, 2006 | 04:11 PM
  #38
camarokid94's Avatar
TSP233-239 OOPS love it
Old Nov 15, 2006 | 09:23 PM
  #39
pdd's Avatar
pdd
id do a custom, (mine will be hear in a few days )get yr scr and dcr perfect for yr combo, after my fifth cam im gonna try to get the perfect scr, dcr and valve events(which i think) for a fast street car and see were im at
Old Nov 16, 2006 | 12:19 AM
  #40
htvette's Avatar
My initial choice was also a 228R. I've read alot of people regreting to go one size bigger so TSP reccomended the V2 torquer. It would be nice to take a test drive on some cam cars but that's kind of hard. I can tell you this is a good streetable mid size cam.
