View Poll Results: Which cam should I used with these heads and other mods?
228R
74
46.54%
TRAK
8
5.03%
MS3
64
40.25%
None of those! (suggest something)
13
8.18%
Voters: 159. You may not vote on this poll
228r or MS3
Old Nov 27, 2006 | 04:05 AM
  #41
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by RoastEmSS
how does the 228 lope on a 112 LSA, im sure its notciable but i need a sound clip
It will have 4° of overlap. So minor lopiness.
Old Dec 7, 2006 | 10:25 PM
  #42
lomaximumta's Avatar
really I have heard a bunch of clips and it sounds pretty damn lopy to me?
Old Dec 7, 2006 | 10:38 PM
  #43
sunsetorang01TA's Avatar
i just installed the TSP 228R. if your looking for still a bit of a daily driver go with the 228. That cam still has alot of lift for big power. bigger is not always better. it's matching your set up. if you want street use out of it a Trex would not suite you. 373s would be alittle more streetible with an MS3 especially if you had a 6spd but believe me for a long time i always wanted the biggest cam out there until i learned. guys run 11.90s with 224 set ups. also getting bigger cams to idle will be quite a hassle especially when it gets heat soaked and starts camming out on u in traffic. i have ideling issues with my 228R untuned now wen it gets hot and its winter now for me.
Old Dec 16, 2006 | 09:03 PM
  #44
bigman's Avatar
Get it tuned. The problem isnt the heqt, it's the tune.
Old Jan 29, 2007 | 07:59 PM
  #45
Phil'sC5vette's Avatar
Saturday I had my car dyno'd and I scored 425.2 RWHP and 400 RWTQ through 3.90s
My tune is way off, and I can gain several more HP when the set up gets dialed in correctly
Old Feb 1, 2007 | 06:17 PM
  #46
dae04383's Avatar
i love my 228r nice lope good #s too. with ls1 heads/ intake
Old Feb 2, 2007 | 08:13 AM
  #47
StreetLethal01's Avatar
I've had the 228/228 .588/.588 113LSA and loved it.
I am definitly going with this cam in the T/A
Old Nov 20, 2007 | 07:24 PM
  #48
itsjustaSB's Avatar
depending on your head camber size and intake setup and exaust setup i would go for something in the 230 range at around 600 lift i run the torquer v2 and love it i put down 428 whp and 410 ftp on a mustang dyno with stock 243 heads with my old setup wont make it to the rollers till next spring im a six speed so that helps with the numbers with a good tune and the right gears you wont have any drivability problems it dosent really act like a big cam set up with the right setup it pulls hard through the whole rpm band 2 gear at 40 i can mash the gas and itll spin all the way through second and bark the tires in the 3 and 4 gear sift on a 295 tire off the bottle i do have 410 gears but i shift into 4 at 100 even hows that for midrange trq
Old Nov 20, 2007 | 07:47 PM
  #49
itsjustaSB's Avatar
ignore my first post i thought you were stock cubes didnt realize you had a 402 i wouldnt put anything smaller than a ms4 in that bad boy and then that will still be a milled cam
Old Nov 20, 2007 | 09:15 PM
  #50
1320 killer's Avatar
in my street car I have a ms3 and I couldn't be happier.
Old Nov 23, 2007 | 07:33 AM
  #51
PREDATOR-Z's Avatar
Thread is old enough, time to put it to sleep
