Hydrolocked the motor today ... AGAIN ..
Fast forward to today - its been over 20k miles since that episode. I drive to work, like normal. Play around a little, but never went WOT. Car drove nice like it always does. Come back out for lunch, jump in the car and hit the key. The starter engages, and then the bendix starts buzzing against the flywheel. I'm thinking its the bracket on the starter had come loose or something, but had it in the back of my mind it might be something else. So after work, I try to push start the car -- it just drags the back tires. "Uh oh" thinks I, and run to a nearby friend's house to grab tools. Pull the spark plugs, and wouldn't you know it -- water pours from the SAME DAMNED CYLINDER as last time.
Took the radiator cap off, cranked the motor over for 15 seconds, put the plugs back in, put some water back in the motor (leaving the cap off) and drive 22 miles or so to the house. Gotta love this motor, it never gets over 195 degrees, even when its hot and I'm sitting at a stoplight
So, it looks like I have to swap gaskets this weekend. Luckily I just so happen to have a set of brand new GM 6.0L MLS gaskets sitting here. The Fel Pro 1041's that are in there, will be no more.
Anyway - I'm obviously thinking its a problem with either the head or the block not being perfectly true. There's no other reason a pump gas N/A 11.3:1 compression setup should be losing head gaskets during street use. Twice. On the same cylinder. Hopefully if its either, it'll be the cylinder heads. Those are easier to bring to the machine shop
Ski
Rebelord, one of my best friends lives in Yuma, but he's more a truck/boat guy
These motors continue to impress me though, I mean c'mon, I drove it home with a bad head gasket The Best V8 Stories One Small Block at Time
J/K that really sucks. Something has to be wrong with they block not being decked correctly. Did you have it decked or at least checked when you had it machined?
The motor is a strong little ****. Lunati H beams, JE flat tops, stock crank. First thing I did yesterday was pull the dipstick, and I didn't see water. When I had the plugs out, it only took a couple seconds for it to build oil pressure with just the starter spinning the engine. Oil pressure when I fired it up was dead on the money -- 70 psi cold idle, 58 psi hot idle.
I'll throw a dial indicator on the top of the piston to make sure the rod hasn't bent, but it didn't last time so I'm pretty hopeful.
Honestly, I'd LOVE to get rid of these heads and put some better ones on there. They aren't exactly great heads, especially since this flow sheet is on a 4.000" bore:
100 200 300 400 500 600 INT 73 154 219 259 287 292 EXH 44 107 145 180 206 218
As for the tune, I'm the one who tuned it. Part throttle I run it a little lean, 15.0 to 16.0 at light throttle cruise. Immediately on throttle tip-in, I go back to normal, around 12.5 to 13.0 .. WOT is around 11.8 right now, a little on the fat side. I have two widebands in the car at all times, don't run narrow bands at all anymore (PCM is in open loop).
1st was finishing up the fiancee's car (370cid, T76, etc.). I got that done while she started pulling my car apart. By the time I finished her car, all that was left was to drop the Y-pipe so we could get the headers out, and then finish pulling the remainder of the head bolts (err. nuts off the studs). She works fast
Anyway, to make a long story short, by eyeball everything looks straight and flat. No visible issues with the heads or the block, but I'll get a more detailed look tomorrow with a straight edge (after I clean up the block). The gaskets, on both sides of the motor, show erosion of the printed blue "seal" around the water jacket holes. It just made it all the way to the fire ring on that one cylinder. The parts that are "missing" on the gasket are primarily towards the middle of the head, but not 100% limited to the middle.
That is a great suggestion. I had a continual leak once & got tired of hearing how fickle aluminum heads were & that machining perfectly flat heads was the way to fix it. In went the Bars leaks (copper based leak repair) & the problem was gone, no excesive heating or any problems since. From now on, any time I change gaskets on a car with aluminum heads, a copper coating goes on the gaskets.
what cylinder?
