Any support mods to run trex?
Old Apr 14, 2006 | 11:37 PM
leftme4dead's Avatar
Default Any support mods to run trex?
With my sig, and the addition of a stall, lt's, ls6 int, is it possible to run a trex? Or will it need any supporting mods. This is not encluding a rear end etc.. Im just wondering if I could install it and give it a streetable tune w/o needing any other mods????
Old Apr 14, 2006 | 11:40 PM
Joel_SS's Avatar
A very good tune will be needed
Old Apr 14, 2006 | 11:45 PM
RoastEmSS's Avatar
u def wont be using all the cams power, because if u spin past 7000 on stop bottom end, BOOM
Old Apr 14, 2006 | 11:58 PM
so I would need a dif bottom end? What rpm could I realistically and safely run to with it??
Old Apr 15, 2006 | 12:49 AM
SVT THIS's Avatar
I'd get new lifters, pushrods, ls6 oil pump and a double roller timing chain. When you pull the heads to put in new lifters you'll need a new head gasket and new head bolts or studs.
Old Apr 15, 2006 | 12:51 AM
Asmodeus's Avatar
and springs
Old Apr 15, 2006 | 01:04 AM
How much should all of that stuff cost??? Not the springs. Ill be getting thep ckage with the cam that encludes springs and what not. Will lifters come with that?
Old Apr 15, 2006 | 02:19 AM
SVT THIS's Avatar
Look around on Thunder Racing or Texas-Speed's website. Its all there.
