cam install kits
Old Apr 15, 2006 | 12:17 AM
Slow00ls1T/a's Avatar
Default cam install kits
Which head and cam install kit is best to go with the 150 dollar kit for tsp or the 250 dollar kit from thunder racing thanks
Old Apr 16, 2006 | 06:41 PM
to the top
Old Apr 16, 2006 | 06:56 PM
SVT THIS's Avatar
Need more info bro.
What is the difference between the two?
What cam are you putting in?
What else is going in with the install?
How many miles are on the car?
Are you installing it yourself?
Old Apr 16, 2006 | 07:10 PM
ohh k putting in the 228r from tsp ls6 prc heads my brother is installing the car has 64000 miles
thunder racing
GM LS1 Cylinder Head Gaskets (left and right side,) GM Cylinder Head Bolts, GM Intake Manifold Gasket Set, GM Exhaust Manifold Gaskets, GM EGR Gaskets, GM Valve Cover Gaskets, GM Vapor Vent Pipe Seals, GM Water Pump Gaskets, GM Front Cover Seal, GM Front Cover Gasket, GM EGR Seals, GM Harmonic Balancer Bolt $269.99
Buy
texas speed
GM head gaskets, GM head bolts, GM water pump gaskets, GM timing cover seal, GM front seal, GM harmonic balancer.
Old Apr 16, 2006 | 07:25 PM
SVT THIS's Avatar
It sounds like the Thunder kit has more stuff to it. However, you might save some money if you right down all the gaskets you'll need, get the GM part number from the parts department at the Chevy dealer, and order it from GM parts direct.
Are you planning on an LS2 timing chain, Ls6 oil pump, etc? If you are pulling the heads you will need some ARP bolts or studs as well.
Old Apr 16, 2006 | 09:28 PM
ya im buying the ls2 timing chain an oil pump Wasnt aware that u needed to bet the arp bolts as well
