broken timing chain?
Old Apr 15, 2006 | 11:27 AM
dirty2kTA's Avatar
Default broken timing chain?
is it possible for a timing chain to partial break?
my car has a crazy internal knock, but it idles fine-no smoke-great oil pressure-no miss-no code-. there is a really bad metal to metal grind when the car is shut off. its not the valve train. i have checked all of that. it doesnt sound like a crank bearing. anything else to check?
Old Apr 15, 2006 | 11:39 AM
92zcamaroperson's Avatar
double roller or stock chain?
Old Apr 15, 2006 | 11:43 AM
dirty2kTA's Avatar
stocker
Old Apr 15, 2006 | 11:54 AM
I wouldnt think so with a stocker. It would be flopping pretty loose and probably hitting the front cover if only half of one of the links was broken. I would think anyways.
Old Apr 15, 2006 | 11:56 AM
and thats saying that it would actually stay together and on the gear....which it would probably come off the gear.
Is that where the noise is coming from? The front cover?
Old Apr 15, 2006 | 12:12 PM
dirty2kTA's Avatar
its pretty difficult to determine the exact location, but when i start to tear it down thats where im going to go first. the noise is louder from the top than the bottom; there isn't anything up there but the valve train. thats why my next guess was the timing chain, but also i dont think it would idle fine if the timing was off. agree?
Old Apr 15, 2006 | 04:52 PM
Rescue Ranger's Avatar
in my older car in college, i had a performance block built - lasted 100 miles (was rebuilt under warranty). the sound your describing sounds like the sound i had.. rod bearing
