Cam only
Old Apr 15, 2006 | 12:49 PM
iquois's Avatar
Default Cam only
I have a stock A4 LS1 in my 98 Z28. What kind of performance increase, if any, would I get from a cam only installation? I would keep everything else as is............I do have a 3.73 gear in car.
Old Apr 15, 2006 | 12:56 PM
BNKBRKR's Avatar
Every car is different but I would say 15-25hp would be a safe guess. If you were to open the exhaust up and the intake (ls6 intake, lid), you might be closer to 30-40+hp. On top of what you would gain off the exhaust and intake work.
Old Apr 15, 2006 | 04:15 PM
wakerider017's Avatar
all depends.... what kind of cam are you looking at?
Like BNK said... GET YOUR SUPPORTING MODS.!!!!
Old Apr 15, 2006 | 09:37 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Get a converter before you get a cam.
Old Apr 15, 2006 | 10:08 PM
Rebelord's Avatar
As Orangeapeel said, get a stall, and if you want to keep your stock manifolds, you can look into the TR Cheater cam.
Ski
Old Apr 15, 2006 | 10:25 PM
vetred's Avatar
Every one of these guys is dead ON and now ask yourself how often does that happen??? You realy must have a compleat "plan" BEFORE you jump!
Old Apr 15, 2006 | 11:18 PM
blkZ28spt's Avatar
Converter before cam.
Bolt ons (especiallay exhaust) before (most) cams.
Quality tuning after cam swap.
You almost certainly do not want to swap cams while keeping everything else stock. There is virtually no reason to do so.
Read the stickies in the new enthusiast, internal and external engine forums. Use the search button. Also check out the automatic transmission section.
