04 gto pcv ?
I have just finished buttoning everything up after removing and selling a magnacharger. I did not install it and the manual says to remove the rubber cap and connecting to the s/c?
Is this just capped off or does it go somewhere on the GTO's. I can't find anywhere that is open to connect up to.
My SS does not look the same for this one last thing and not sure what is needed. install manual does show.
it should be a little "U" shaped hose about 3 inches long that you use for the connection...
many people use catch cans in this spot to remove the "blow by"
