ls6 intake on ls1 heads and vice versa?
I don`t understand this I thought that the intake and the heads better have similar size for best results (intake runner on heads and what`s facing it on the intake)
there is a difference in the size or the intake runner between the ls1 heads and the ls6 heads right?
so how does the ls6 intake fits the ls1 heads? and 2001 -2002 f-bodys came with ls6 intakes and the had ls1 heads as everbody knows but is it the same exact intake on the zo6 cars that have the ls6 heads? see how much I`m writing about this it`s a little
http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg
https://ls1tech.com/forums/generation-iv-internal-engine/483587-7-piston-failure-fix.html
Thanks for your replys guys
But ....I know that they fit (ls1 on ls6 heads and ls6 on ls1 heads) and the difference in volume and it`s clear for the bottum of the intake shape ....
My question is Ls1 and Ls6 have different intake runner size on the heads right? so how come the intakes just just swap between them without any modification necessary to either the heads or the intake? isn`t it best if the size of the intake holes pefectly match the heads intake runner size? I`m still
maybe the answer is simple but I don`t know it Trending Topics
maybe the answer is simple but I don`t know it The Best V8 Stories One Small Block at Time
and what about ls1 intake on ls6 heads if they don`t match and you directly bolt them on what`s the use of the larger intake runner size on the ls6 or the ported ls6 heads?
anybody thought of that question and got the answer?
Nelson.
it helps if you`re correct and I`m all wrong!
what I`ve understood from reading about ls1`s and ls6`s is that the valve Size is the same LS6 being lighter valves on the intake ... and the intake port on the heads are bigger (203cc or so on ls1 and 218-220 on ls6) .... anybody else? the subject isn`t the intake port size but if they`re the same then no meaning of this thread as I was completely wrong and the ls6 heads flow better because of the valves being bigger ....
but if I was correct then again the same question on the ls6 intake port size not matching ls1 heads and ls1 intake small ports on ls6 or aftermarket ported ls6 heads (people that put heads and cam heads being ls6 based and use stock ls1 intake saving money to get a fast 90/90).
Nate
Nate
me<----not asking why it makes more power or worth it
me<---- asking if ls1 intake and ls6 intake have diff intake port sizes and if so read the above questions I`m tired of retyping the question in diff ways
Nate_Taufer <---- thank you for the info about the ls6 port size
