anyone think jb weld will fix this
HAHAHA, JB weld is pretty good for a lot of thing but for this, HELL NO, yolu can try it though and possibly destroy the motor. heres something you might want http://cgi.ebay.com/ebaymotors/LS1-h...spagenameZWDVW hurry up its almost gone
A lot of the casting where it broke looks pretty thin. Maybe just a bad casting from GM caused it to be weak there especially after the porting. Those look like 918s. What is the lift of the cam?
they are 918's the lift is .581. The general reply I've got from the people I've talked to is they think it could be from the porting. so tomorrow I'm going to pull the heads and check everything out.
Yea, looks like th eroof/walls are very thin. That area has to hold the spring pressures, and obviouslly, that was a bad spot in the aluminum. Could be a casting defect, and the addition of the thin walls equals problems.
