Texas Speed Torquer v.2 Camshaft VS FUTRAL MOTORSPORTS FM13
Old 04-18-2006, 01:42 PM
just1news6's Avatar
Thats a good question what type fo springs cause that was what i was considereing 918s because dont you have to take the head off to have the head machined for duals??? is there anyothers that wouldnt require machining
Old 04-18-2006, 01:44 PM
GuitsBoy's Avatar
No. Patriot gold duals, PRC gold or platinums, or TEA duals all drop right in. Theyre all outstanding value for the money, and you simply dont hear of failures with them.
Old 04-18-2006, 01:47 PM
just1news6's Avatar
Where can you buy them at and do you what type of pushrods do you think would be needed? andy part numbers? can you get a pachage deal with pushrods, springs, retainers and ?
Old 04-18-2006, 01:50 PM
GuitsBoy's Avatar
Many sponsors carry them. Try patriot performance directly, or Texas-speed who carriers PRC stuff. They usually run around 250-275 for the kit. Just about any hardened pushrod will do. On stock heads, id go for a 7.425 length PR. They usually run around 100 - 125. Youll also need a few misc gaskets and a pulley bolt and whatnot.
Old 04-18-2006, 02:30 PM
Checkmate's Avatar
I go with an LG cam. You cannot beat proven track/dyno numbers and their customer service.
Old 04-18-2006, 03:01 PM
SVT THIS's Avatar
Would the Torquer 2 make more power than an MS3? If running 3.73s and a 4000 stall which would ya choose>
Old 04-18-2006, 03:47 PM
HolyShiznit's Avatar
The MS3 is a bigger cam and has proven to make more peak numbers than the T2. You have to rev the motor a little more with the MS3 though.
Old 04-18-2006, 04:28 PM
SVT THIS's Avatar
Ya but I figure when you floor it you floor it. If you have your shift points set at 6800 it shouldn't be a big deal. Esp. if its powerband starts at your stall speed (4000 in my case). So would the MS3 be a better idea than the Torquer 2?
Old 04-18-2006, 05:45 PM
PREDATOR-Z's Avatar
MS3 should in a properly setup combo give you 15 rwhp more across. Is this for a drag combo? If not MS3 is too big, as well as Trq V2
Old 04-18-2006, 11:42 PM
Quik's Avatar
i know ppl are using dual springs but has anyone actually used 918s with a T2?
Old 04-18-2006, 11:59 PM
SVT THIS's Avatar
This is for a drag/street racing car Predator-Z. Many people have advised me on the 228R but the guys at TSP told me the Torquer 2 or the MS3 would make me more happy with my 4000 stall and planned 3.73 gears. Are they wrong? I understand peak hp, but if I floor it every time I race, whether the street or the track, and my stall flashes to 4k rpms and I keep it nailed through the gears, wouldn't the MS3 be the best?
Old 04-19-2006, 12:10 AM
  #32
just1news6's Avatar
good questing quick
Old 04-19-2006, 12:16 AM
  #33
badboyracingws6's Avatar
My friend is using 918s on the T2 and he daily drives his car. In fact it is the car that they put the dyno graph on the TSP website. I've talked to him about it and he says he has no problems. 415 rwhp, no head work, 02 Z28, M6, 4:10's, pacesetters, duals, and some suspension work.
Old 04-19-2006, 09:01 PM
  #34
just1news6's Avatar
so do yall think an ls7 clutch would hold up to the abuse with this cam and some drag radials and waht should i expect to run quartermile wise with this cam
Old 04-20-2006, 05:14 AM
  #35
PREDATOR-Z's Avatar
Actualy your 4K stall will fit the trq V2 better, MS3 needs at least that much but will benefit more from a 4400+
Old 04-20-2006, 08:21 AM
  #36
SVT THIS's Avatar
So the Torquer 2 would be a better choice over the 228r and MS3 with my setup? Thanks
Old 04-22-2006, 11:47 AM
  #37
02CamaroZ28's Avatar
You guys with the Torquer 2...where are you shifting with a M6?
Old 04-22-2006, 12:31 PM
  #38
GuitsBoy's Avatar
6600 to 6700. I peak at 6300 but Ive only got two degrees advance ground in.
Old 04-22-2006, 12:36 PM
  #39
sounds good, btw im looking at the 112 lsa.
Old 04-22-2006, 02:33 PM
  #40
CraZee ZO6's Avatar
So if your shifting at 6700-6800rpms why not just go MS3 anyway if it will give you 15rwhp across the board.
Quick Reply: Texas Speed Torquer v.2 Camshaft VS FUTRAL MOTORSPORTS FM13
