Your Thoughts on a 228/232 .588/.595 110LSA +2
Old 04-23-2006, 09:30 AM
04LS1GTO's Avatar
Originally Posted by Josh
Hey Guys,
I'm about ready to pull the T-ReX in favor of something a bit more street-friendly, and after a good bit of research and fooling around in the cam spreadsheet, I've come up with an XE-R "lobed" 228/232 .588/.595 110 LSA on a 108 ICL.
My goal is to significantly increase torque and power in the mid-range and reach peak power at around 6300 RPM.
The cam will be spinning under stock 853 heads and enhanced with the normal array of bolt-ons, including a ported TB, LS6 intake, Hooker LTs, 3" Mufflex Y-Pipe, cutout, and March UD pulley. The power is sent to a Moser 12-bolt housing 3.90 gears, and, occasionally, I spray a 100-150 shot.
The valve events look like this (at .006, .05, and .200, respectively)...
Code:
Intake Valve opens - IVO	30.5	 6	-33.5
Intake Valve closes - IVC	66.5	 42	 2.5
Exhaust Valve Opens - EVO       72.5     48	 8.5
Exhaust Valve Closes - EVC      28.5	 4	-35.5
Exhaust Centerline - ECL	112	 112	 112
Overlap 	                59	 10	-69
If my calculations are correct, my DCR should be around 8.1:1.
Any input you all have to offer would be very much appreciated. I'd hate to spend the time and money to do this swap only to discover the cam in question works horribly.
Thanks,
Josh
Who makes this cam and where can I get it?
Old 04-23-2006, 09:34 AM
SideStep's Avatar
Just call CompCams directly and order it....
The lobe serial #s are:
Intake: 3724
Exhuast: 3726
Make sure you explain to them you want a 110LSA and 108ICL (if that is what you want)
Old 04-23-2006, 09:52 AM
Viper's Avatar
I've got a 227/231 571/578 111 no advance and LOVE the low end torque. Good choice on cam!
Old 05-01-2006, 01:33 PM
Dom
Dom's Avatar
Has anyone dynoed the 228/232 110 +2 cam yet?
I was just reading the AFR 205 thread and Tony Mamo @ AFR says the 112 version needs the pistons notched so I'm guessing the 110 won't work at all with those heads.
https://ls1tech.com/forums/showthrea...=495344&page=2
What heads will this cam work with? I can't afford AFRs anyway, but was wondering what my choices are. When I saw that post I got worried. I'm looking at TSP PRC LS6 CNC heads and Dark 205 heads. Will those work without any clearance issus? I'm going to be stock heads for a while, but eventually want to get some heads.
Old 05-01-2006, 01:34 PM
Dom
Dom's Avatar
Any track times or dynos?
Old 05-01-2006, 06:05 PM
okls1's Avatar
I am thinking about the same cam only 110+1 and it comes out like this.
This looks good too right? Just wanted to make sure no objections before I buy. But was little concerned about 110 lsa on the street dd but if the cam gods say its cool Im all over it
IVO 5
IVC 43
EVO 47
EVC 5
ECL 111
Overlap 10
Old 05-01-2006, 07:46 PM
Ragtop 99's Avatar
okls1:
Go for it. A 1* change in ICL will have a only minimal change in the cam's behavior; maybe even undetectable. The change is well within potential grinding error (e.g. both a 110 and 111 ICL cam could be delivered as 110.5).
Old 05-02-2006, 03:08 PM
Viper's Avatar
"Any track times or dynos?"
In signature
Old 05-02-2006, 03:49 PM
onelife's Avatar
What exactly happens to the cams profile if you advance it 2+ degrees with an adjustable timing gear.
Old 05-02-2006, 03:58 PM
Viper's Avatar
http://www.hotrod.com/techarticles/1...am/index2.html
Old 05-02-2006, 06:21 PM
okls1's Avatar
I just ordered this cam comp 228/232 .588/.595 on 110lsa +2 with comp 918s and 7.425 pr. Should be here next week I cant wait. Got it from Speed inc. 600 to my door. Ill post up results after install
Old 05-02-2006, 07:47 PM
  #32
MooresGTO's Avatar
Just curious why the 7.425 Pushrods?
Old 05-02-2006, 08:03 PM
  #33
JBIRD02's Avatar
Smaller base circle. 7.425 should ensure proper preload to help eliminate the "sewing machine" sound. However, with aftermarket heads, smaller gaskets, or milling, you will need to check for proper length.
Old 05-02-2006, 11:07 PM
  #34
8banger's Avatar
That cam will be nice on the street because the LSA will drop the power band down a few RPM's. It should be just a bit higher than stock RPM wise, with big gains in power.
Old 05-02-2006, 11:32 PM
  #35
Asmodeus's Avatar
very similar to mine. 228/232 but I got the intake on an lsk lobe with .639 lift, and a 112+2 to ease the low end torque on street tires (i won't run slicks) and spin a bit higher. plus a 100 shot for special moments.
Old 05-03-2006, 12:15 AM
  #36
okls1's Avatar
Like Jbird said the cam has smaller base circle so 7.425 should make it run better. I went with predator's suggestion because he seems to be the pr master Yes I cant wait to get this cam in, but with this and the 4.10s I wont have traction until 4th gear
Old 05-03-2006, 12:16 AM
  #37
PREDATOR-Z's Avatar
It is more than a bit, 42 IVC will make it peak at 6200 rpm, so shiftpoints will be 6500/6600
Old 05-03-2006, 06:54 AM
  #38
Ed Curtis's Avatar
In signature
Vid: http://media.putfile.com/HUMBLER
Time for a 6000+ launch!
Old 05-03-2006, 07:18 AM
  #39
Viper's Avatar
Not on my 10-bolt!! lol
Old 05-03-2006, 09:02 AM
  #40
gen3toy's Avatar
im running a comp 232/232@110,no fly cutting needed and have 440rwhp
Quick Reply: Your Thoughts on a 228/232 .588/.595 110LSA +2
