Rocker arm bolt
Old Apr 16, 2006 | 11:46 PM
Ackattack1's Avatar
Default Rocker arm bolt
Hey guys, I'm going to be doing a cam swap next weekend, and rather than using a rocker arm bolt with the valve spring tool, I'm going to get a lenght of all thread to use. I think that will be easier.
Does anyone know the thread size of that bolt?
BTW, I'm also going to get a longer bolt to install the pulley while I'm at the "screw store".
Thanks
Derek
Old Apr 17, 2006 | 09:51 AM
Ackattack1's Avatar
No one knows?
Old Apr 17, 2006 | 11:31 AM
ArKay99's Avatar
Originally Posted by Ackattack1
No one knows?
pretty sure it's 8mmx1.5mm
Old Apr 18, 2006 | 10:37 AM
MrShimmy's Avatar
do a search for the rocker arm bolt part number. It is under the parts number sticky thread and I think it gives it. 8mm x1.25 thread is what I remember.
Old Apr 18, 2006 | 11:13 AM
dregnier0's Avatar
8mm 1.25pitch and about 60mm long. I actually reused one or the water pump bolts and put a small socket as a big washer on it to get the right length. Worked fine for me.
Ryan
