Where to find valve cover breather
metco makes one that is expensive as hell. I know thunder racing sells it.
I'd also like to know if there is a cheap alternative or a good way to vent the stock driver side cover.
For the LH side I cut the plastic PCV hose off the 45 degree thing that goes in the grommet then put a little 7/16 ID K&N filter on it. Fits tight and isnt going anywhere.
You can see it in this pic..
Originally Posted by kp
I use the metco on on the RH side, you see them used pop up for 25.00 or so - thats where I got mine
sweet, thanks. I think thats is what I'm going to do. right now I just have the stock cross over line. do you think your way is better than that?
Probably not any better but I dont have that plastic line running around the back of the motor anymore. Less clutter behind the intake..
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Is this a good idea for a stock engine.??? most engines just have a cap...will this release alot of pressure.??? GOOD? or BAD?
I went to autozone and got two of their small breathers I think 5/16 ID not sure at all though. anyhow it's slightly bigger than the gromets that the pcv hoses hook onto. I put one on the rear grommet on the pass. side and one where kp has his on the driver side. oil cap is still there capped off the fresh air line to the tb and valve cover and capped the intake. Works great no oil anywhere and no more smoke out of the exhaust. Cost me about $20 IIRC.
speed inc sells the breather you are talking about phil.
