Cam Swap
Old Apr 18, 2006 | 05:28 PM
LastHawk02's Avatar
Default Cam Swap
WHat else should you do when you swap out your cam, besides a oil pump, springs and pushrods?
Old Apr 18, 2006 | 06:35 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Change coolant and oil+oil filter.
Old Apr 18, 2006 | 08:08 PM
dregnier0's Avatar
Titanium retainers if you plan on reving the engine high and definatley a new timing chain. LS2 timing chain is prob fine.
And the above stuff.
Old Apr 18, 2006 | 09:14 PM
yak's Avatar
yak
cam, spring ( i would get duals if your getting a big cam), pushrods, coolant, oil +filter, timing chain, waterpump gaskets, new crank bolt.
Old Apr 18, 2006 | 10:58 PM
zo6vetteman2003's Avatar
Add assembly lube to the list and a good telescoping magnet. There is always something else you forgot.
Old Apr 18, 2006 | 11:48 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
918's will suffice for most people's taste in cams.
Old Apr 19, 2006 | 12:31 AM
99camarosupersport's Avatar
i'd go with the prc's duals for safety myself. hardened pushrods, ported ls6 oil pump, timing chain and all the gaskets and you should be set.
Old Apr 19, 2006 | 05:20 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Duals are always great insurance.
Old Apr 19, 2006 | 06:38 AM
PREDATOR-Z's Avatar
And don't forget http://www.ls1howto.com
