Double roller needed for MS3
Old Apr 19, 2006 | 02:36 PM
SVT THIS's Avatar
Default Double roller needed for MS3
Hey everyone, I was originally planning on going cam-only with the TRex but have changed my mind again and again and finally decided on the MS3 with a set of heads. I already have the double roller I was going to use with the TRex. Should I sell it and go with an LS2 or should I do all the work required to make it fit and go with the double roller? I may or may not spray with the MS3 it just depend on what kinds of numbers/times I see. Would it be safe to go with the LS2 chain instead? Thanks
Old Apr 19, 2006 | 02:55 PM
killaz's Avatar
i would stick with the ls2. should be more than enough
Old Apr 19, 2006 | 03:47 PM
formula402's Avatar
LS2 would work nicely....
Old Apr 19, 2006 | 03:51 PM
35thls1ss19's Avatar
i have the ls2.... thats all you will need
Old Apr 19, 2006 | 03:52 PM
steveb's Avatar
Just did my MS3 with PRC LS6 heads and i also used the LS2.
Steve
