6.0 Heads Vs 5.3 Heads
5.3's have a smaller chamber, 6.0L have a better set of ports. I would do the 5.3L from TEA or if I wanted to go all out, 6.0L's milled down alot and ported for another 30-40cfm more than the 5.3's
Bret
It's easy to get 11:1 compression from the 5.3's with slight milling, where the 6.0's would take quite a bit. 6.0's would be better for FI applications or strokers.
Correct me if I am wrong guys... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
LS1derfull I have only seen 300cfm numbers out of 5.3L heads and 340cfm numbers out of 6.0L heads. So if you have seen 5.3L heads that flow more tell me about them, because I might want a set.
If you have the extra cash for the 6.0L cores then get those puppies milled down and have them ported. That's a more expensive way to go but it will work.
Bret
