Head Bolts or Studs
Old Apr 21, 2006 | 11:43 AM
Zymosis's Avatar
Default Head Bolts or Studs
Give me some pro's and cons of going with head bolts or head studs from ARP, or even going with stock bolts......
I guess I'm saying, give me some direction in this decision
Old Apr 21, 2006 | 12:46 PM
daryl2cb@yahoo.com's Avatar
well, studs are usually more money, and usually better piece of mind, great for FI cars if not a requirement, and works well with no2 applications as well. The bolts are good, studs are better, but if you are not going to crazy bolts should be ok for you, what are your current plans? I mean, where is this going.
Old Apr 21, 2006 | 12:50 PM
777's Avatar
777
Head studs - Never have to worry about cleaning bolt holes again, makes install of new heads easier if need be. Some say they it's hard to find the clearence. Strongest of all.
Head bolts - Easy install, still have to clean bolt holes, stronger than stock.
Stock head bolts - Easy install, still have to clean bolt holes, will work, but still have to do the stupid torque method with degrees and stuff. Plus you risk breaking one if you don't do it right.
Old Apr 21, 2006 | 12:57 PM
Bad30th's Avatar
Go with ARP studs and never look back. Easy future head swaps, no more cleaning bolt holes in the block, better tensile strength and you'll never have to buy another set of head bolts, much less worry about torque-to-yield and degreeing, etc.
...oh, and I have done head swaps with the motor in the car, some people say there are clearance issues but that's not true.
Rob (Bad30th)
Old Apr 21, 2006 | 01:08 PM
Zymosis's Avatar
Rob (Bad30th)
Okay, that was also one of my worries, was having fitment issues with the studs sticking up. But I shouldnt have a problem getting the heads all the way to the back and sitting on the studs with the engine in?
Another question, hex vs 12 pt? what size hex bit does it take/what size 12 pt?
thanks fellas, this is really the direction I was looking for
Old Apr 21, 2006 | 01:11 PM
ROCNDAV's Avatar
Rob (Bad30th)
Yup. I was contemplating going with studs because of their cost (and the fact that I already had new factory bolts). But I'm glad I did. I've had those heads on and off so much, I couldn't imagine doing that with factory bolts.
Another plus for studs is that it saves the block threads from possibly getting stripped.
Old Apr 21, 2006 | 01:13 PM
Bad30th's Avatar
100% correct, I swapped my last set of heads with the block in the car. No problem getting them on/off.
Just gotta be careful and take your time, like everything else. It's not like there's a shitload of room like there is on a 'Vette, but the heads will come on/off and will fit under the cowl with the studs installed, no problem.
Rob (Bad30th)
Old Apr 21, 2006 | 02:52 PM
Black Z/28's Avatar
No problem with clearance here. Studs are expensive but after reading so many posts about broken bolts and stripped threads I decided they were worth the price. It was so easy (and stress free) tightening the nuts down to specs. And if I ever have to pull them...
Old Apr 21, 2006 | 02:53 PM
Zymosis's Avatar
What size hex bit does it take/what size 12 pt?
And what are the torqing specs/procedure for the studs?
Rob (Bad30th)
Thanks Rob
Old Apr 21, 2006 | 04:36 PM
Bad30th's Avatar
http://blackcamaro.com/headstud.htm
Good instructions ! Take special note of the torque on the top smaller bolts, lots of people overtorque and break them.
Also, here's a scan of the install instructions that come with the studs (thanks to whoever posted this) :
Not sure on the exact size of the hex key. Easy enough to figure out when you get them, or you could probably call ARP and ask if you need to know beforehand.
I can look when I get home (rode the motorcycle to work today).
Cheers,
Rob (Bad30th)
Thanks Rob
Old Apr 27, 2006 | 08:50 PM
Zymosis's Avatar
Ha to my suprise, a 230 dollar box of ARP studs does not come with a small thing of moly lube.
Cheap bastards, lol. Will motor oil work okay, or should I just buy some damn lube
Old Apr 27, 2006 | 09:22 PM
is should have two spec of torque for moly lube and oil
Old Apr 28, 2006 | 05:36 AM
vettenuts's Avatar
Cheers,
Rob (Bad30th)
Note that the two instructions posted differ from each other. The pre-stretch on the web site is for rod bolts not head bolts/studs as verified by the head tech at ARP. I would say use at your own risk.
The studs offer full engagement of the threads in the block before any load is put on the block threads, in my opinion, that is the best reason to go with them in an aluminum block.
Old Apr 28, 2006 | 10:48 AM
Zick's Avatar
Plus it just looks cool to see the stud sticking out of the block like that.
Rob (Bad30th)
