whats needed for 241 castings?!
Old Apr 21, 2006 | 12:08 PM
cartekls1's Avatar
Default whats needed for 241 castings?!
so I just got some heads. there the 241 castings. I have a 98 SS that will be recieving them. anything need to be changed?!
Old Apr 21, 2006 | 12:12 PM
ZERO's Avatar
The valve covers also, if u dont have them already.
Old Apr 21, 2006 | 12:39 PM
8GTOKLR's Avatar
head gaskets are diff too..make sure the year you order is 01 and newer.
Old Apr 21, 2006 | 12:40 PM
777's Avatar
777
valve covers, coil pack bracket (you need two), (2) head gaskets for a 01+ ls1, not the 98 graphite's, get the MLS.
Old Apr 23, 2006 | 04:14 PM
lowchevy2go's Avatar
you can get coil brackets at a gm dealership for like 12 buck a piece. The bolt holes for the coils are not pre-tapped. Most people get a tap and tap them but i took a coil bracket bolt and put it in my cordless drill and sprayed some wd-40 in the hole and screwed the bolt in. went right in and threaded perfect.
