valve seal help
Old Apr 21, 2006 | 05:03 PM
2000 Ultra Z's Avatar
Default valve seal help
how do you seat the valve seals. I bought the ms3 kit from tsp with the prc dual valve springs. Tried them twice how my friend said but they keep comming up to the top of the spring and leaking.
Old Apr 21, 2006 | 05:28 PM
98hc4mula's Avatar
grab a socket that bearly fits the top and pound it in untill you feel it go all the way down. you will notice a change in the sound as you pound it in. use a 11mm I think to seat them with a hamer. hope that helps
Old Apr 21, 2006 | 05:55 PM
NassyVette's Avatar
Yup...make sure you lube 'em up good before you put em on.
Old Apr 21, 2006 | 09:11 PM
thank you
Old Apr 21, 2006 | 10:31 PM
Quik's Avatar
i told you!!!
Old Apr 22, 2006 | 02:33 AM
StreetnStrip's Avatar
Closed ex-Sponsor Account
Originally Posted by Quik
i told you!!!
and u were also told to clean all the dirt out of ur lifters and then soak them in oil but no u didnt. Atleast the seals werent as costly *** the fuckup u did *****.
Old Apr 22, 2006 | 10:23 AM
Quik's Avatar
lifters were clean bonehead, **** was still in block.
Old Apr 22, 2006 | 11:17 AM
no bonehead u didnt soak the lifter like u were suppose to. i guess ur LS1bible didnt tell u to do that did it.
Old Apr 22, 2006 | 11:54 AM
Rescue Ranger's Avatar
Can.... you feel.. the LOVEEE.. tonite..
Old Apr 22, 2006 | 12:30 PM
Quik's Avatar
gues you didnt see when i did lube them up many times like supposed to. excess debris in motor that floats around then sets ontop of lifter will do that. without doin a complete tear down of a motor that hit a tree, you dont know what is going ot happen. but i what i did know is to seat valve seals
