Valve locks want let go?
Old Apr 22, 2006 | 11:37 AM
00SS4780's Avatar
Default Valve locks want let go?
I broke a dual spring and now trying to change them. But the locks want let go! Any suggestions. They are dual springs on patriot heads. Thanks
Old Apr 22, 2006 | 11:48 AM
UltraZLS1's Avatar
After the springs are pressed down try tapping on the end of the valve...where the locks are. I usually sit a magnet on top right next to the locks while I am tapping on them in case they go flying...a good stong magnet will catch them...you dont want them flying somewhere, falling into your engine, losing them etc etc.
If they still wont come loose...then something else is wrong...maybe the valve that the broken spring is on got bent to hell.
Old Apr 22, 2006 | 11:50 AM
chriswtx's Avatar
Give the retainer or valve a light tap while the spring is compressed a little...
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Try hitting the retainer with a small hammer at an angle before using the spring compressor on it.
Old Apr 22, 2006 | 12:05 PM
00SS4780's Avatar
Ok thanks guys. I am attempting to change all of the springs but they all are stuck. I have tapped on them compressed and not compressed to no luck.
Old Apr 22, 2006 | 12:23 PM
00SS4780's Avatar
Ok, nevermind and thanks. I hit the retainer with a hammer and a peice of wood and it broke loose. Thanks again.
Old Apr 22, 2006 | 12:34 PM
99blancoSS's Avatar
Yep, good show. After having the first three stick when I did mine I just did the same thing. Tapped them all with a block of wood and a hammer.
