PCV remove
I change my oil frequently anyway so I am ditching the pcv.Type in pcv and pvc in search (people type it both) and there's alot of info.
On 98's you can put it on the driver or passenger when using the screw in Metco. On 99-02's you have to run it where the oil fill cap is unless you buy another passenger valve cover. The reason is because 99-02 have center bolt covers and 98's are perimeter from what I can tell. You can go get different breathers and clamp them on and it would be cheaper. I just want it for looks and I can swap back easily if I ever have to have a visual inspection for emissions.
duh, intake oil!, clean engine bay! problems?
