How to measure valve springs
Old Apr 24, 2006 | 12:01 PM
silverado01's Avatar
Default How to measure valve springs
I just bought a pair of used 918's and was wondering what all I can measure to make sure there within spec. Do I just measure spring height, O.D. and I.D. with a caliper while off the car. Can I measure coil bind, seat pressure, or anything? How? Do I measure anything while the springs are on the car?
Thanks for the help
Old Apr 25, 2006 | 11:43 AM
anybody?
Old Apr 25, 2006 | 12:13 PM
GuitsBoy's Avatar
You can compress the spring and a bathroom scale in a vice. Compress till the spring measures installed height (1.800") then simple read what the bathroom scale says. It can be accurate within a couple of pounds.
Old Apr 25, 2006 | 05:27 PM
Red99C5's Avatar
The easiest would be to take them to a local automotive machine shop and have them check the spring pressure. Somehow I don't see how you can hold a bathrooom scale in a vise, hold the spring, and turn the vise...........with only two hands. Besides, it would have to either be a very small bathroom scale, or a very big vise. The bathroom scale would work better with an arbor press.
Old Apr 26, 2006 | 10:01 AM
sounds good, thanks
Old Apr 26, 2006 | 01:26 PM
Ryan02SS's Avatar
I have a Tavia valve spring gauge that I use in conjunction with a set of dial calipers to measure the spring height. I use my bench vise to apply pressure to the spring. Works great and is pretty accurate.
