Under Drive Pulley guys please chime in
Old Apr 26, 2006 | 05:41 PM
AJay's Avatar
Default Under Drive Pulley guys please chime in
My engine is going to be apart soon for a H/C install and I'm thinking about installing an UD pulley. What are the trade offs / down sides (if any). I understand 8 - 10 RWHP is a realistic gain but any air conditioning / charging / low voltage at idle isssues to contend with??
Thanks for your input :thumbs:
Old Apr 26, 2006 | 05:49 PM
AnotherScreenName's Avatar
Nope. Do it.
Old Apr 26, 2006 | 08:17 PM
eallanboggs's Avatar
Let's say you're sitting at a long red lite on a hot summer nite with the A/C "ON" and your 1,000 watt stero blasting. If you can live with your dashboard lites dimming a little you might be OK.
Old Apr 26, 2006 | 08:35 PM
sickss228's Avatar
I've got the ASP and had no problems whatsoever. Do it
Old Apr 26, 2006 | 08:39 PM
2mffZ28's Avatar
ASP a4.........no probs.
just crank pulley no big stereo
Old Apr 26, 2006 | 10:42 PM
98LS-WON's Avatar
Do it while the engine is apart. There realy isn't a downside.
Old Apr 27, 2006 | 01:16 AM
racecar's Avatar
Go for it. Idle, headlights on, no voltage problem. I don't have AC.
Old Apr 27, 2006 | 07:58 AM
GuitsBoy's Avatar
Just wantch for thrown off belts. If your lights dim too much, you can get the overdrive alternator pulley.
Old Apr 27, 2006 | 02:59 PM
Azar's Avatar
LS1TECH Sponsor
Dooo Ittt!
Old Apr 27, 2006 | 03:15 PM
Viper's Avatar
No problems here, no thrown belts with the March pulley.
Old Apr 27, 2006 | 04:26 PM
Ryan02SS's Avatar
ASP 3 years No thrown belts and no charging problems...
Old Apr 27, 2006 | 04:40 PM
2001blackta's Avatar
2 1/2 years with an UD crank pulley with non problems.I say do it.
Old Apr 27, 2006 | 06:32 PM
I've taken GM Powertrain classes and the instructors claim that the thrown belt problem (A/C) can be solved with a reflash and this is with regular service bay drive in customers not guys who visit LS1 Tech and have underdrive pulleys. Point being if you have an ASP pulley and the A/C belt comes off chances are it isn't the pulleys fault.
Old Apr 27, 2006 | 08:59 PM
98LS-WON's Avatar
What exactly is a reflash? I don't have the belt problem I'm just curious what it is because that sound like a computer thing to me but I can't think what that would have to do with a belt coming off.
Old Apr 27, 2006 | 09:09 PM
GuitsBoy's Avatar
I think he means that its able to be tuned out. I for one dont see how this is possible. Its clearly a mechanical issue.
Old Apr 27, 2006 | 09:12 PM
Mach 5.7's Avatar
I have the SLP UD pulley. Gage shows decharging @ idle especially with lights on. I'm sure it's shortening the life of my battery but not to worry. I deleted A/C though. The system won't have that to contend with. Don't get a new alternator pulley! That would defeat the purpose!
anyone who says they're not a bitch to install probably doesn't have it tight enough. That's what I'm sayin.
Old Apr 27, 2006 | 09:40 PM
Even though I've heard different instructors say it I too find it hard to believe a reflash can solve a belt problem. I don't have any proof either way. Unless your local garage has a library of PCM files you'll have to go to your local GM dealer for a reflash.
Old Apr 28, 2006 | 01:57 AM
Anthony Williams's Avatar
I have a March fliud UD pulley No problems but I do have a Optima battery and I put it on a 2amp charge every couple weeks or so. I did throw a belt but that tensioner had 95K miles on it replaced the tensioner, no more thrown belts.
Old Apr 28, 2006 | 04:42 AM
WS6 #3392's Avatar
I have a SP u/d pulley and have had no problems what so ever in 2 1/2 years. Go for it.
