Are MLS head gaskets reuseable?
Old Apr 28, 2006 | 04:30 PM
Ditmeion's Avatar
Question Are MLS head gaskets reuseable?
...just like the title says.
TIA
Old Apr 28, 2006 | 06:54 PM
02RedHawk's Avatar
yes...
Old Apr 29, 2006 | 12:50 AM
HAMRHEAD's Avatar
They can be depending on condition. It is usually a good idea to replace them when you swap heads. Not saying they won't work but then you wasted a lot of time if they don't.
Old Apr 29, 2006 | 02:18 AM
beardWS6's Avatar
Do it right the first time. Get new ones.
Old Apr 29, 2006 | 05:00 AM
eallanboggs's Avatar
Damn right they're reuseable. Hell, I even recycle toilet paper when it's close to payday. Condoms too. You're so cheap you probably squeak when you walk.
Old Apr 29, 2006 | 10:12 AM
2c5s's Avatar
Wow!!
Old Apr 29, 2006 | 10:32 AM
Spinmonster's Avatar
Cometic said they are.
Old Apr 29, 2006 | 10:34 AM
SUX2BU's Avatar
I have reused stock MLS head gaskets before but unless you know you might be swappin heads a couple times i'de just buy some new ones.
Old Apr 29, 2006 | 01:30 PM
Haans249's Avatar
Buy new ones man, I just pulled my heads when I used MLS gaskets, and they fell apart when I pulled them up. The rubber tends to stick on the metal surfaces from the pressure and will usually, if not always, tear here and there. At that point, they're finished.
Old Apr 29, 2006 | 10:40 PM
GuitsBoy's Avatar
This is how mine always are. GM MLS anyway.
